Gabe
by Gabe » 11 Sep 2002 20:54
I'm going to take out the inner layer of canvas on my lavers, but i'm not sure how. anyone done it before? Do i first take out the insole? do i take out all the seams around the shoe laces? what exactly do i do?
floyd
- Shredalicious
by floyd » 11 Sep 2002 21:09
Not that I use lavers but I have modified about 5 pairs, taking out the inside canvas is definetly a good idea. You will have to remove the insole, you will want to replace it with a thinner one that deosn't push the clipper area outward.
Do not remove the leather around the laces!!
Its quite tricky the first time may take you a number of hours, but it is necessary, see
http://www.footbag.org on how to do it all.
Dat
by Dat » 11 Sep 2002 21:41
I remove the canvas by starting slowly, using an exacto knife to cut one thread of canvas at a time until i have a nice line cut. Then i pull at that opening to seperate the canvas from the nylon. You should be able to figure out at that point by yourself.
CL: openFrameworks
Gabe
by Gabe » 12 Sep 2002 14:15
You say not to remove the leather stuff that goes down with the laces. But the seams that hold that in place, go all the way through both layers of canvas. what am i supposed to do?
Gabe
by Gabe » 12 Sep 2002 14:20
I think i get it now. Am i supposed to just remove the soft canvas in the inside of the shoe ( the part you do clippers and inside delays with)?
That makes more sense. I thought i was supposed to take out ALL of the inner canvas.
Dat
by Dat » 12 Sep 2002 14:48
yeah i just take out a section of the inside part of the canvas. some people take out sections of canvas from the toe and the outside, but that isn't necessary.
CL: openFrameworks
Bono
by Bono » 12 Sep 2002 14:48
and the toe and the outside
because its best to be able to have that thinness on all sides (except the heel obviously) because you can feel the bag and set it better.
i like to kick the little footbag thing around and move my legs around it and stuff
Gabe
by Gabe » 12 Sep 2002 14:52
Yea, i just did the toe and inside. its REALLY NICE!. i just gotta make all the cuts cleaner.
Gabe
by Gabe » 12 Sep 2002 15:24
ok finished the outside. One shoe took me about an hour. I'm doing the other tomorrow. Hopefully its worth it.
d0tard
- Shredalicious
by d0tard » 12 Sep 2002 15:47
I don't want to start modifying my lavers until i get an insole and i was wondering if you guys know any particular good type and where i could get it
Marc Legault
Dat
by Dat » 12 Sep 2002 18:03
Flat green spenco insoles made of neoprene are popular. They sell them at every other athletic shoe store for under ten bucks.
CL: openFrameworks
Matt
by Matt » 12 Sep 2002 19:25
cant you just do a little snippity-snip on the old insoles to make them... not so wide?
anyway, how are you supposed to get those ones out? they are glued down and stuff
Like every man of sense and good feeling, I abominate work
-Aldous Huxley
floyd
- Shredalicious
by floyd » 12 Sep 2002 19:32
I have tried that and I found they were still too thick and pusjed into the arch of your foot a bit also. Definitely go with the green spencos.
You can pull them out quite easily even though they are stuck down (some more so than others), you may have to scrape some of the remaining foam off the bottom of the shoe though.
Gabe
by Gabe » 12 Sep 2002 19:43
Does taking out the inner mesh make the shoe less durable so it just "comes apart" after alot of use?
floyd
- Shredalicious
by floyd » 12 Sep 2002 19:49
Jabi wrote:Does taking out the inner mesh make the shoe less durable so it just "comes apart" after alot of use?
It does make them less durable, of course, but I haven't heard of any properly modified shoes having the outer mesh come apart.
ToeGuiltless
by ToeGuiltless » 12 Sep 2002 20:10
Spenco COURT/AEROBIC insoles. Make sure they are court/aerobic for the forefoot cushion.
Gabe
by Gabe » 12 Sep 2002 20:44
Is taking out the Inner mesh REALLY REALLY good? does it make quite a difference in your freestyle experience? or not much of a difference at all, just a small thing to make you be able to feel the footbag better.
Bono
by Bono » 13 Sep 2002 08:44
heh... my foot doctor took the liberty of mercilessly ripping the insoles out of my lavers the day after I got them
so I couldn't really tell you whether it makes a difference to have an insole because I haven't had any for a looooong time.
Danno
- Shredalicious
by Danno » 15 Sep 2002 10:41
I removed the insole of my lavers when I was taking out my inner canvas and never really put it back in. Even without the insole, my lavers are much more comfortable than any other shoes I have worn
Danny Iachini
Kranberry Kickerz
Matt
by Matt » 15 Sep 2002 14:32
you should probably have an insole so you dont ruin your legs
I was at scheels and they had some blue lavers !(just like the red ones but... you know), only 50 bucks too. But they were womens, and I didnt have any money on me.
-Aldous Huxley
