Ultrasuede Soft?
billyg
Ultrasuede Soft?
Post by billyg » 28 Nov 2011 18:03
Has anyone tried using ultrasuede soft in their footbags? I like ultrasuede light, but on Fields Fabrics, there are so many colors for ultrasuede soft that I'd like to use. Also, ultrasuede soft is cheaper. Does anyone recommend it?
Billy G.
Post by mahhkohh » 30 Nov 2011 03:16
ultra suede soft is alot, ALOT, thicker than us-light! you can break it in, but it takes brutallity and lots of patience! keep that in mind. but as allways, go ahead and check it out, maybe try the sample pack from fields, there is allways some us-soft in there. it can be used, but its not close to us-light
will_T
Post by will_T » 06 Dec 2011 19:14
it's very difficult to make a playable bag with soft, unless it's a very large demo bag, and even then you want to only use it for pentagons. i tried lots of combinations, and the best results weren't all that great. Then again I gave up on them before anything that could be called a real break-in period had taken place...
Post by mc » 09 Dec 2011 00:48
This stuff should be renamed "Ultrasuede Suck".
billyg
Post by billyg » 09 Dec 2011 03:24
Alright! Thanks to all of you guys I won't waste my money on any.
Billy G.
