Climacool 1 Modification Tutorial
- PegLegHolly
- Swashbuckler
hhaha you know what... i didnt even read the front of the tube to check that... i just grabbed it from work because its white and its "all purpose caulk" but my dumbass didnt read... "acrilic latex caulk"
hahahahhahahahhahahahaimadumbasshahahhahahaha
im leaving right now to walmart... this time ill check for 100%
- PegLegHolly
- Swashbuckler
Kyle Hewitt
- something more funny
Pretty sweet on the mod for the insides. I bet this will take away a lot of frustration in modding them when it's with this method.
- PegLegHolly
- Swashbuckler
well i took the toe mesh off and... WOW... it really does make a difference.
my climas bring all the boys to da yard... and theyre like... its betta than yours... damn right... its betta than yours!
enough of that.
my new euro climas are being shipped to me tomorrow from france an will arrive in 5 or so days!!! they are marroon/green/yellow... does anyone have these? if so, does the mesh come off the toe the same way the clima1 mesh comes off? do the french shoes differ much from clima1s? i dont want to mess these ones up.
enough of that.
- mosher
- brutal footbag cronie
Erik, brocka mods are required based on anatomy. If you crank and there is material pressing against some part of that part of your ankle/foot then trim it there. I have a giant brocka on my climas because i am one of the people that really needs it.
Not everyone needs a brocka mod!
g00d33
I started to take off the rubber fins and stripes. The fins came off no problem. The stripes are a different story. I tried slicing at the top like the fins but I guess I hit the mesh. I've tried a couple different angles but none are any good. Was there a different way to take off the stripes? Or should I just keep pressing forward and come back to this stripe later? And the stripe I'm having trouble with isn't the stitched stripe (just for clarification) Any help would be appreciated!
John Goode
- zeroman13
The big stripes were and are the hardest part to modding clima's.
Here's what I did for them.
I cut the top of the stripe like the little fins. And when I thought I got deep enough, I started a little cut at an angle. With that angled cut, you should be able to pull on it and separate it from the mesh some. The slowly pull and using whatever tool you used to cut, slowly cut the back of it away from the mesh.
Hope that helped.
Hope that helped.
