32 Panel Color Patterns
Donovon
Post by Donovon » 10 Jan 2010 19:25
Alright, I know there was a thread that covered this before (which can be found here). However i thought that id try to pick this apart the best i could, for the likes of both stitchers and buyers. I tried my best to find capture different angles. I will try my best to give credit where credit is due (i hope people don't mind if I use their pictures). I am terribly sorry if I have left you out.
Here goes:
Every 32 Panel Bag consists of:
12 Pentagons
20 Hexagons
Every 32 panel color pattern is basically a play on those numbers.
Solid:
Color 1- 12 pentagons/20hexagons
Andrew Kownirk-Dunford (Eskimo Joe)
Michał Biarda (Cod)
Standard/Soccer Ball:
Color 1- 12 Pentagons
Color 2- 20 Hexagons
Hanna Mickiewicz (Hania)
Paradox:
Color 1- 6 Pentagons/10 Hexagons
Color 2- 6 Pentagons/10 Hexagons
Mike Paras (mikep)
Brian Dennis (Brinard)
Spiral/Spinner:
(pent - hex - pent - hex - pent - hex - pent - hex - pent - hex - hex - pent - hex - hex - hex - hex)
Julien Cote (akalazou)
***Variations (One solid spiral, One alternating spiral)
Waylon Lew (Wasabi)
Bi-Polar/Bizarro/Flip-Flop-
Will Tuttle (will-T)
***Variations- 5 Claw: Polar pents will match the surrounding color (essentially switching places)
12/8 Blur:
Color 2 (X)- 12 Hexagons
Color 3 (Y)- 8 Hexagons
-Around every pentagon there will be 3 of Color X and 2 of Color Y
-Color X will form multiple doubles
-Color Y will never touch eachother and will form squares
***Variations- Color 2 or color 3 may be identical to color one, making two possible 2-color blurs
Marco Hartig (mahhkohh)
J. Chris Miller (Shredzilla)
Tri-Color (Hex-Center):
Color 1/2- 3 Pentagons/4 Hexagons
Color 3- 6 Pentagons/12 Hexagons
Will Tuttle (Will_T)
Quad-Color (Hex-Center):
Color 3/4- 3 Pentagons/6Hexagons
Waylon Lew (Wasabi)
Tri-color (Pent-Center, I would center around the yellow one in front)
Color 1/2- 4 Pentagons/6 Hexagons
Color 3- 4 Pentagons/8 Hexagons
Michał Biarda (Cod)
Ninja-Star Pattern:
Color 1/2- 6 Pentagons/10 Hexagons
Waylon Lew (Wasabi)
Tri-Claw:
Colors 2/3- 3 Pentagons/10 Hexagons
Brian Bear (brianbear)
(One of mine "half-way done")
***Variations (Which is likely more common, a true tri-claw) Only 2 colors- the 6 pentagons of color 1 are divided among colors 2 and 3.
5-color star:
Color 1/2/3/4/5- 4 Hexagons
Color 6- 12 Pentagons
Waylon Lew (Wasabi)
Sam McAulay (bluntobj3ct)
*Variations- 5 colors can either run straight through to polar star or be flipped to the polar end of the bag (making it seem like you made two identical halves and stuck them together, but twisted 180 degrees)
5-Color Swirl:
Color 1- 2 Pentagons
Color 2/3/4/5/6- 2 Pentagons/4 Hexagons
[Each color looks like: hex - pent - 2 hex - pent - hex]
Donovon Thakur (Donovon)
6-Color Swirl:
Color 1/2/3/4/5/6- 2 Pentagons/3 Hexagons
Color 7- 2 Hexagons
[one line of color is: pent - hex - pent - hex - hex]
*Variations (which chronologically prolly came first, but are easier to explain first seeing the 6 colors)
-Spinner triclaw: 2 colors, basically alternating lines, with polar hexes opposite colors
-Tri-Swirl: 3 colors (well, 4 if you include the polar hexes), basically two adjacent lines are identical in color (2x3=6!)
Color 1/2/3- 4 pentagons/6 Hexagons
Color 4- 2 Hegagons
6 Stripe
Color 1/2/3/4/5/6- 2 Pentagons/2 Hexagons
Color 7- 8 Hexagons
6 Egg
Color 7- 8 Hexagons
Atomic:
Color 1- 12 Pentagons/4 Hexagons
Color 2- 16 Hexagons
2 color- Sam McAulay (bluntobj3ct)
***Variations (4 middle hexes of radiation to color 3)
***Variations (4 Radiations different colors)
4 color- Cale McCoy (calemccoy)
Fearless 55 Pattern: 8 radiations of different colors
Color 1/2/3/4- 3 Pentagons/1 Hexagon
Color 5/6/7/8- 4 Hexagons
True Fearless 55- Richard Abshire (richardabshire)
Dada- Random (usually involves lots of colors, but not always)
Erik Savage (Shred Villan)
Poke' Bag:
Color 1 (Red)- 6 Pentagons/5 Hexagons
Color 2 (White)- 6 Pentagons/ 3 Hexagons
Color 3 (Black)- 12 Hexagons
*There are other ways to make a poke' bag, this is just one. There are also different poke' balls you can imitate.
As far as putting them together, I personally consider there to be two types of patterns: Those that center themselves around a pentagon and those that center themselves around a hexagon. Generally, this really only makes a difference when looking at a bag and is pretty obvious. However, to me it makes a difference in how i physically put the bag together. I hope I can explain this correctly.
Pentagon Centered:
Probably "easier." After the first flower, the five pentagons are added around that. (then 5 more and you are left with the last pent)
12/8 Blur //// Spiral
Sorry, i typically do this with my phone.
Hexagon Centered:
These patterns, to me, once you get half way, put themselves together. However, with a hexagon as a center, you might need to sew 3 pentagons to be able see the hexagon as the center.
6 color spiral //// 4 color atomic
Sorry again about the quality.
It might not exactly fit, but i wanted to include this:
The difference between the two-stitch bags and the three-stitch bags are as follows:
Matt Cross [i](slightly modified)[/i] wrote: -feel - two-stitch bags are a little stiffer to start (because the thread is further from the edge of the panels, so there is more material on the inside of the bag)
-appearance - the edges on two-stitch bags are not as straight as the edges on three-stitch bags. This is purely cosmetic
-cost - two-stitch bags take less time [to stitch]
From here, this is pretty much the best advice anyone could offer when attempting to crack a new pattern:
Wasabi wrote:
Matt Cross wrote:when making a new color pattern for the first time, find a picture of the same pattern.
Focus on ONE pent at a time, and the colors surround it. start with a pent that is very... "important" to the color scheme. ie: the "tip" of a claw, the beginning of a spiral, etc etc. Just get that first pent down. Then find out how other pents of the same color, or part of the same part of the pattern, relate to that starting pent.
So, pick a good starting pent, go very slow, and focus on one at a time. if you do that, you can do any pattern.
I love color patterns :D
Props everyone on nice bags!
Hope this helps,
~Donovon
Edit: Looks like the site hosting my photos changed servers or something, I had to edit all of the links. Sorry that they have been down for awhile. Let me know if this happens again (although i hope it doesn't, lol)
Post by mc » 10 Jan 2010 20:23
Hi Donovon,
Maybe take out the part about size, as that has more to do with stitching style and the templates.
1. feel - two-stitch bags are a little stiffer to start (because the thread is further from the edge of the panels, so there is more material on the inside of the bag).
2. appearance - the edges on two-stitch bags are not as straight as the edges on three-stitch bags. This is purely cosmetic.
3. time - two-stitch bags take less time [to stitch]
will_T
Post by will_T » 11 Jan 2010 10:48
great thread! this will surely help many people who are trying to figure out some of the more complex color layouts.
and matt, when you make 2 stitch bags, why do you bite deeper from the edge? does it have to do with bag growth during break in? i sew both styles the same distance from the edge, but you've got more experience than a lot of the folks on here. thanks :)
Post by mc » 11 Jan 2010 10:53
I stitch my 3-stitch bags very close to the edge.
The stitches are bigger on 2-stitch bags (using the same templates) so if I were to stitch as close to the edge on a 2-stitch bag as I do on a 3-stitch bag, the corners of the panels would pop out, making an ugly flaw in the bag.
akalazou
Post by akalazou » 12 Jan 2010 10:40
i would add, dont be shy, i you dont understand a patern that someone created, ask him how he made it ... Donovon asked me for a patern iv called "toxic" ... i dont know what i meant by that, but if i knew, it would be a pleasure to help him out. so you can ask me anything about patern, and prolly that MC, Waylon and some more stitchers can help you too.
Julien Cote
Donovon
Post by Donovon » 12 Jan 2010 12:59
Thats a good point. Awhile ago i could only find a picture of one side of the 6 stripes pattern on Brian's bag, so i asked him to help me out.
I was mostly looking for the so called toxic pattern so that i could include it in my thread.
~Donovon
Donovon
Post by Donovon » 11 Feb 2010 17:51
*Added Julien's new eggs pattern
Post by Wasabi » 12 Feb 2010 05:48
I believe I made this bag.
Good guide.
Donovon
Post by Donovon » 12 Feb 2010 06:29
Wasabi wrote:[img]
Good guide.
Terribly sorry. Perhaps he posted a pic of your bag. I went through a lot of posts. Fixed now.
~Donovon
will_T
Post by will_T » 13 Feb 2010 19:01
hey all, i'm experimenting with some new concepts so to mock them up on paper first i made this. figured i'd post it in case anyone else can use it.
akalazou
Post by akalazou » 13 Feb 2010 19:37
Julien Cote
will_T
Post by will_T » 14 Feb 2010 13:08
i searched for about half an hour to try and find that thing before just giving up and making my own. thanks for finding that link :)
it's never worked for me though, every panel i click just goes white and i can't select any colors. using firefox 3.
Justin Hall
Post by Justin Hall » 14 Feb 2010 15:55
You have to match that circle to the circles of the colors on the left perfectly and left click your mouse for the color to change.
will_T
Post by will_T » 14 Feb 2010 16:51
well darn my socks! it works!
Donovon
Post by Donovon » 30 May 2010 15:11
Thread expanded to include 5-color swirl and a poke' bag design.
~Donovon
Brad Benson
Post by Brad Benson » 22 Jun 2010 10:54
Forgot the eye ball.
Ramen God
Post by Ramen God » 08 Aug 2010 11:31
Hey donovon, I need your pattern figuring outing skills for a bag I wish to make. It is called the Yin Yang and I have been trying for a couple months to figure it out how to put it together, but I just can't do it.
It is the upper right image. If you can, please help me figure out how to do this pattern.
zachatree
Happy Hippy Hoffa
Post by zachatree » 08 Aug 2010 15:25
dgsadgaj the eyeball!!!! awesome i have to try that!
Ramen God
Post by Ramen God » 09 Aug 2010 04:50
Yeah, the eyeball is sweet.
Donovon
Post by Donovon » 09 Aug 2010 14:47
To be honest, myself and others have tried to figure out that pattern before. But its really hard without a picture of the back.
My best adivce would be to try the tri-color design. But take three adjacent colors one color and the other three a different color, and switch the polar hexes, while surrounding them by the other color. So youd have the single hex, surrounded first by the opposing color (same thing on the other side) and the rest of the bag would be a mix of that tri-color design.
If you try that, post a pic.
~Donovon
