Gyro Butterfly/Down
janis
Gyro Butterfly/Down
Post by janis » 21 Apr 2007 06:21
SET>BACK (SPIN) [BOD]>SAME OUT [DEX]>OP CLIP [XBD][DEL]
This trick is driving me mad, any tips are greatly appreciated.
Post by mc » 21 Apr 2007 08:18
practice gyro clippers. Then, set a bit higher, and as soon as you set, open up your hips by pointing out the knee on the set leg as you spin. Then, as you do the butterfly, do a bit of a hop forward. that helped me get it. That's the way it looked like Eli Piltz would do it.
Post by acxel22 » 11 May 2007 07:35
gyro legover is a good trick to school if you want to hit gyro butter.
Post by Sporatical_Distractions » 11 May 2007 07:58
I focus on keeping my knees fairly close together from the set until opening up for that butter.
janis
Re: gyro butterfly
Post by janis » 26 Mar 2008 05:58
janis wrote:This trick is driving me mad, any tips are greatly appreciated.
still driving me mad...
Sergey
Post by Sergey » 27 Mar 2008 10:19
I'd say work on spinning and gyro clippers as much as you can. Here's a little video I made:
http://www.youtube.com/watch?v=2Q2zQM_BzOo
Hope this helps!
Sergey Pikalov
Post by Jeremy » 27 Mar 2008 23:56
Yeah having seen you playing recently, I'd say really school spinning clippers, gyro clippers and infinities. If you find gyro butterfly difficult, I can't imagine there being any other reason than your components for the move are lacking. The same applies to pretty much all multiple component moves.
janis
Post by janis » 28 Mar 2008 00:07
I think my gyro clippers are the weak link, so I started drilling them today :)
Post by Jeremy » 28 Mar 2008 00:16
Sweet. I'd try to do them "muted" style. ie. Don't plant the support foot until you do the clipper. It looks cooler and will help with gyro moves more. Also maybe drill muted gyro legover (ie. no plant).
