Illusion
Illusion
Illusion
SET >> OP OUT [DEX] > OP TOE [DEL]
http://www.hackrifice.com/minisooper/2illusion.mpg
Can someone give me some tips on illusions? i just cant get them down. I either 'the' them or i just do it horribly wrong.
I dont know what to do!
Greetings Henry !
Are your illusions more up time or all down time ?
I just ask, because there is a slight difference
between the two.
To me, illusions are so much easier when done
up time, the down time version i just learned
recently...as for the first style,lets assume right toe :
i set the bag and as soon as it leaves my foot,
i hop of the supporting leg immediatly,performing
a quick out to in dex with my left leg ( thigh ).
Because the bag's still on its way up, the plant with
the right leg can be done while "completing" the dex.
When the dex is cleared, you plant the dexing leg,
raising the right foot to toe stall the bag .
Down time illusions, like in pixie illusions are harder,
since you plant the setting foot before you dex, some
what like a normal legover bailed to op toe.
As you see, i'm not tooo good at explaining stuff, but
maby it helps..
between the two.
maby it helps..
EASYKINKI
lol!
@ seath : all this uptime illusioning jazz is the foundation
to atomic stuff, sure, and if u think, dexing the bag with
your upper leg instead of your calf makes an up time illusion
an atomic toe stall, then thats kool aswell
@ gauntlet: a dex is "the", if its not clean. and again, check out
flipsider.com for all kinds of information about lingo and moves,
ellis is definitly one of the good guys.
EASYKINKI
- crazydwarf
I haven't ever done them until you just mentioned them here so I don't know if this is the best way, but when I tried it I got it a couple times. It seemed to help to do the same kind of foot work as you do in mirage (by footwork I mean like when you leave each foot, and the rythm of the move). But then when your leg goes go over with your thigh and then forget about that leg and it'll finish the dex by itself. Then concentrate on getting the toe stall... hope that's how it's supposed to be done, and Im not just making up horrible advice.
Dustin Rhodes
Make sure you do these -downtime-! If you do your fundamentals midtime or uptime, or leggy when they're supposed to be hippy (or visa versa) you'll have a hard time combining concepts. Do moves how they're supposed to be done unless you have no interest in progressing very far (which is fine, obviously :-p). You'll spend a lot of wasted time relearning concepts.
hmmm...well simple logic tells me, if you have two ways
of doing something and both possibilities are valuable,
one would profit the most, if he knows both ways.
In this case, uptime illusions are fundamental to atomic
sets, and the downtime version is good for stuff like
pdx illusion, pixie illusion ect.
Both ways serve certain purposes, so if you really wanna
progress very far, which obviously very fine, then it you
should know both : )
But nagasake, who definitly knows about atomic, is right,
when he insists on downtime illusions ; they are harder
and look "nicer", especially when you do one as a single move.
But i think its incorrect, to state that learning uptime illusions is
a waste of time, am i wrong or can you do quite explosive stuff
with those ?
with those ?
EASYKINKI
I really do think learning uptime isn't too useful, though, unless you plan on doing your atomics leggy. You can do atomics hippy in which case learning illusions doesn't really help. My point is that when you're not too far into the game, you should learn it downtime as to avoid the bad habit of throwing midtime and uptime illusions in midstring. The same applies to leg over, mirage, etc. It is a matter of choice, but this is just my opinion on the matter. Leggy atomic can be really cool, after all, and you're right, it is useful to learn things as many ways as possible.
There are two ways of doing it, like the leg over. You can hop to give yourself the momentum to get over it, or you can set, then a quick dex and quick stall.
With the hopping, it's like a legover bailed to the op toe. There are 3 distinct contacts with the ground. set dex land. That's the rhythm of it.
With the quick dex, you set it, then dex and catch in almost the same action. it's more like set dexland. It really does depend on your style the way you do it.
John D
Here's the error...
Could not insert new word
DEBUG MODE
SQL Error : 1016 Can't open file: 'phpbb_search_wordlist.MYI' (errno: 145)
INSERT IGNORE INTO phpbb_search_wordlist (word_text, word_common) VALUES ('debug', 0), ('entered', 0), ('post', 0), ('sorry', 0), ('thing', 0), ('triple', 0), ('weird', 0)
Line : 234
File : /home/jer/modified.ca/docs/footbag/includes/functions_search.php
DEBUG MODE
Line : 234
John D
- Blue_turnip
Personally I think that uptime illusions are 100% useless in helping your atomic sets. They are so different. Its like saying that being good at stepping sets automatically make you good at blazing sets.
With uptime Illusions you dex with your shin and calf area and its a kind of whip action. With Atomic set its all hip and you dex with your thigh.
In most ppls oppinions uptime illusions are easier and i am no exception. However if I got to choose which way I would love to perfect it would be downtime as that helps you with other moves and it just looks better
Oliver Adams
- tuomoruutufan
i find this trick easiest when you bend you dexing legs ankle as if your doing an inside stall. like previously said dont think of it as reverse mirage so dont try it the same way its easier to get cleanly dex the bag when arch your ankle.
I will now practice downtime illusions since i only do them mid/up time leggy style.
But isnt that method usefull if your gonna do a symp illusion?
~Shawn Patrick Boyle~
