Taylor's Challenge Page
Challenge your friends to hit tricks/combos you know they can hit, even if they don't!
TayChaint
Post by TayChaint » 27 Aug 2007 13:44
ok, i can do all of the basic stalls, mirage, legover, around the world [both ways], butterfly, osis, pickup, and paradox mirage and am working on my pixie set. if anyone could give me some drills for really solidifying BOP's and some challenges i would appreciate it!
EDIT:
Things I've Hit:
Butterfly>Pdx. mirage Rpt.
infinityx20
Osisx25
20 ss clipper bs
ssbutterfly>osis>pdx mirage rpt.
butterfly>mirage>legover>legover>ss butterfly>osis>repeat
Osis > SS Butter > RPT
mirage>ss mirage>rpt 12 contacts
ss butterfly > far legover > rpt
mirage x3 > ss mirage x3 rpt
pixie legover>pixie legover
Miragex5>ssMiragex5 rpt
legover x5 > ss legover x5 > rpt
20 contacts of legover > ss legover>repeat
legover > pixie legover
mirage > pixie legover
pickup > pixie legover
plo>plo rpt
pixie pickup bs
illusion bs
ss illusion bs
legover x 30
A string of 10 BOP's, all mixed up.
whirl>infinity repeat
stepping ss legover BSOS
stepping op osis bs
Near and Far Legover and Pickup all BSOS in the same run (total 16 contacts, 8 toe moves, 8 clippers)
Pickup x 10
50 infinities
ss osis > pdx mirage > opp osis > pdx mirage > rpt
butterfly > pdx mirage > ss butterfly > pdx mirage > rpt
butterfly > ss mirage > butterfly > ss pickup > rpt
[mirage > ss mirage] > rpt > [mirage x3 > ss mirage x3] > rpt
ducking clipper x 2
pickup x3 > ss pickup x3 > rpt
plo>smear rpt
pdx mirage>legover>butterfly>osis>infinity>osis repeat
pixie same mirage x3
dimwalk>pdx mirage repeat
15 ducking clippers each side in one session
Things I Have Yet to Hit:
SS butterfly>osis>pdx mirage>rpt as many times as you can
stepping ss pickup BSOS
Illusion BS. Then Illusion > Pickup > RPT
Make Christine get Lavers
illusion>ss illusion>rpt
ducking clip>diving clip>rpt
gyro clip>gyro clip
ducking toe x 4
diving toe x 2 (both sides)
ducking toe > diving toe > rpt
starting from toe: ducking clipper > ducking toe > ducking toe > rpt
ducking mirage?
paradox illusion --- super jenky
Taylor Chaintreuil
Post by HG » 27 Aug 2007 16:12
Hey taylor, it was cool to meet you (and christine)!
Here's some stuff
legover x 30
butterfly>pdx mirage repeat (if thats too easy, do 12 contacts of this)
osis x 8
20 same side clippers both sides
Iron Clad Ben
Superior Precision Bionics
Post by Iron Clad Ben » 28 Aug 2007 07:26
Hey Taylor
:arrow: Illusion BS. Then Illusion > Pickup > RPT
:arrow: Near and Far Legover and Pickup all BSOS in the same run (total 16 contacts, 8 toe moves, 8 clippers)
:arrow: Make Christine get Lavers
:arrow: Pickup x 10
:arrow: 10 infinities, if too easy 20 infinities
:arrow: Mirage > SS Mirage RPT, if too easy 12 contacts
:arrow: SS Butterfly > Osis > PDX Mirage > RPT
:arrow: Osis > SS Butter > RPT
And I bet you could totally hit ducking clipper BS if you tried.
Zeb Jackson
Post by Zeb Jackson » 28 Aug 2007 08:57
what kevin was showing you at worlds x infinity (the number not the trick ;) ).
i dont remember, if i introduced my self at worlds or, not, but hey, nice seeing you :lol:
Post by Sporatical_Distractions » 28 Aug 2007 10:31
gyro clip>gyro clip
p.s. met you at worlds. nice routine
TayChaint
Post by TayChaint » 29 Aug 2007 04:06
Thanks guys!
it was nice meeting all of you at worlds, Zeb i think i might have been in a circle with you for about 2 minutes during some routines or something. anyways, last night i had time to footbag for about 15-30 minutes and hit:
Osisx8
20 ss clipper bs
Taylor Chaintreuil
qphox
Bullshit Detector
Post by qphox » 29 Aug 2007 12:47
I don't think anyone's game at Worlds impressed me as much as yours did Taylor! You keep this up, and I'm confident you're going to be nothing short of world class in no time at all.
Things to try:
- starting from toe: ss osis > pdx mirage > opp osis > pdx mirage > rpt
- butterfly > pdx mirage > ss butterfly > pdx mirage > rpt
- butterfly > ss mirage > butterfly > ss pickup > rpt
- ss butterfly > far legover > rpt .......I don't seem to recall you doing any far legovers in Orlando. Maybe you were, idk.
- [mirage > ss mirage] > rpt > [mirage x3 > ss mirage x3] > rpt
- mirage x5 > ss mirage x5 > rpt
- legover x5 > ss legover x5 > rpt
- pickup x3 > ss pickup x3 > rpt
The longer drills are obviously going to be tougher, as they demand near 100% consistency, but I think you could do them. Just make sure you're executing everything as efficiently as possible, and it'll be CAKE.
I'm aware that you've hit the pickup drill, but I seem to recall it being considerably weaker than your other toe stuff...so just hit it again. ;) Oh, and remember to resist the urge to "scoop" each delay, eh?
- ducking toe x 4
- diving toe x 2 (both sides)
- ducking toe > diving toe > rpt
- starting from toe: ducking clipper > ducking toe > ducking toe > rpt
- ducking clipper x 2
- ducking mirage?
There's this thing I used to do when I first began to try ducking tricks: Set the bag to the height at which you would normally duck it, but don't. Instead, just close your eyes for a split second. Practise doing that more and more, and try increasing the time for which your eyes are closed. It may help to train your mind to get used to just "knowing" where the bag is without necessarily being able to see it. This comes back to your sets having as little arc as possible: if it's up and down, you should know generally where the bag is, and where it's going to be once your head gets out from underneath it. Make sense?
- legover > pixie legover
- mirage > pixie legover
- pickup > pixie legover
The basic idea here is this: You've got a universal "start position" for your entire toe trick repertoire. It's all begininng from the same spot (or rather, it should be). SO, theoretically, you should be able to link any uptime component FROM any downtime component. It's all about balance. If you finish legover correctly, you should be able to pixie out of it just as easy as if it were simply a toe delay. Same goes for mirage, pickup, illusion, dlo, eggbeater, doublepickup, massacre, barrage, and anything else that ends on toe. (My biggest challenge right now is flail(symp illusion) > atomic. I really want atomic flail > atomic flail.)
Same goes for clipper of course, but who needs 'em, right? ;)
ABOVE ALL: Keep in mind that if it's taking you more than 10 tries to hit something, you'd probably be well advised to take a step back and work on the basics. Absolutely, it can be fun to go big...but in the end, that's all it is. Fun. Your body isn't really going to learn anything from trying paradox drifter just yet. If your intention is to practise, you should be training your body through consistent repetition, not teaching yourself how to drop.
I think that's enough for now. Get to it. :)
..oh, one more thing:
- illusion. :P
- Kevin R.
F = G*((m1*m2)/r^2)
Know thy enemy.
BrianP
Post by BrianP » 29 Aug 2007 14:58
Throw in some paradox illusions in place of mirage in a bunch of the aforementioned drills for something different, you'll have more uniques as well as working your muscles for eventually adding atomic stuff. Also, the best pixie drill for me was (and is) plo > smear rpt. or plo > plo.
Today is what you make it. So, like, don't screw up the recipe. ^^
TayChaint
Post by TayChaint » 06 Sep 2007 17:22
Thanks Kevin for all of your help at Worlds, i really appreciate it. and thanks for all of these drills! i've had a bit of time to footbag and have updated my list at the top of the page. some things i hit that wern't really challenges were:
ss legover x3>legover x3 rpt
clipper>clipper rpt. [the clipper where it's like a drifter without the dex]
pickup> sspickup rpt. [trying not to scoop]
butterfly>far legover x5 for both sides
butterfly>mirage x5 for both sides
Taylor Chaintreuil
qphox
Bullshit Detector
Post by qphox » 21 Oct 2007 20:10
Any more progress? :D
- Kevin R.
F = G*((m1*m2)/r^2)
Know thy enemy.
Post by PegLegHolly » 21 Oct 2007 20:24
she posted in a private thread the other day:
parkwalk bs
dimwalk bs
pixie legover > smear
GO TAY!
cd
Post by cd » 24 Oct 2007 22:33
Great to hear that pixies are working out! Can you repeat that PLO>smear?
How about more new tricks? Your foundation moves all sound like they're coming along, and you could get the hang of more 3's while you solidify your BOP game.
There are too many to learn all at once, but the next step for you might include whirl, drifter, dlo, spinning, ducking, stepping, or double around the world.
Definitely focus the most on your foundation tricks. Learning to do longer strings will be much more productive than hitting big moves at this point. But you're progressing very well, so it's a good thing to spend a little time each session trying new things.
I challenge you to hit:
Paloma Mayo
Post by Paloma Mayo » 25 Oct 2007 12:24
Hi taylor it was nice to meet you at worls, as I read your game is becoming really nice!
thank for adding the videos to youtube
here are some stuff
pdxmirage<smear<pixie legover<ilusion
duck but x 2
whirl<osis<whirl
TayChaint
Post by TayChaint » 04 Nov 2007 10:17
thanks for the challenges and advice chris, i really appreciate it and i should look at this thread more often :oops:
i've been working on some basic drills and working on pixie sets. they're starting to almost have some sort of consistency. i still need a lot of work on them but i'm finally seeing some results! today/since i last posted i've hit:
legover>ss legover rpt. 20
ss legover x 5 > legover x 5 rpt.
mirage>pixie legover bs
legover > pixie legover bs
pickup > pixie legover bs
legover > magellan bs
ss legover > magellan bs
ss mirage>parkwalk>osis bs
ss mirage>dimwalk>osis bs
Taylor Chaintreuil
qphox
Bullshit Detector
Post by qphox » 24 Nov 2007 00:26
the x5 legovers really made me smile! Glad that the whole odd-numbered repetition dealio is working out for you! I'm sure it'll be no time at all, and you'll be throwing a pixie set in front of all those. :D
Feel like updating us on what your abilities are like now? Y'know, so we can all challenge you appropriately. :)
(That's a request for a new video btw)
- Kevin R.
F = G*((m1*m2)/r^2)
Know thy enemy.
QuantumBalance
100-Watt Warlock
Post by QuantumBalance » 24 Nov 2007 01:28
CHALLENGE FOR A NEW VIDEOOOOOOOOOOOOOOOOOOOOOOOOO
Taylor you are my hero!!
TayChaint
Post by TayChaint » 27 Nov 2007 15:47
i will try to make a video soon!
on sunday i hit pixie legover > pixie legover rpt. 6 contacts to hand catch! they were a little delayed inbetween each but i was pretty happy :P
Taylor Chaintreuil
Post by mc » 28 Nov 2007 09:42
go taylor! Cut down on the lag time between plos, that's my next challenge. those are a VERY important thing to drill. The pixies lead to quantum sets, and the legovers lead to illusions. Also try pixie pickups. How about infinities back and forth? I challenge you to hit 50 b2b.
once you can do 8 or so b2b, 50 will come quickly. just focus on your breathing and your form. you can do it.
TayChaint
Post by TayChaint » 04 Dec 2007 17:06
interesting short session:
illusion bs!
ss illusion bs
pixie pickup bs
Taylor Chaintreuil
QuantumBalance
100-Watt Warlock
Post by QuantumBalance » 05 Dec 2007 05:29
I donated 160 really large grains of rice!!
edit i also found this
http://www.palmbeachpost.com/npost/cont ... index.html
you have a post worlds picture there! I like your hair and you look confident!! cheers
-sam
