Online Fun String Ranking - Post your string!
Online Fun string Ranking
You can post your best unique string's here and be ranked against the rest of the players who post on this forum!
What is a unique string?
Strings where no moves are repeated on the same side are unique. Ie mirage>legover>mirage>legover is a unique run because none of those 4 moves are hit twice on the same side.
The strings are judged on contacts not on add value, so the aim is to hit strings as long as you can, not nessisarily as hard!
This is how it works:
You hit a string as long as you can that follows the rules of the particular competition, and post it on this thread.
The strings value is the total adds in the string. Contacts is how many moves you hit. There is a top10 for each event.
Fun Events:
ALL STRINGS MUST BE UNIQUE
Dexless - your string must contain no moves with dexterity components.
Double Dex - your string must contain only moves with TWO dex's each.
Tripple Dex - your string must contain only moves with THREE dex's each.
Toe Run - you can only use your toes as the delaying surface for any move in your string.
Clipper Run - you can only use clipper as the delaying surface for any move in your string.
Unique Delays - strings may only contain delay components, stall the bag in as many different places as you can!
Unique Sets - strings must contain as many consecutive unique sets as possible (toe/clipper set don't count as sets).
Unique Symps - your string must contain as many consecutive unique symposium moves as possible!
Unique Downtime - your string is allowed to contain no sets apart from toe and clipper.
Best Unique Strings
Dexless(Must be Guiltless)
1. Nate Linscott(Eugene, OR) - spinning ducking clipper > inspinning clipper > spinning clipper > inspinning clipper > spinning osis > ducking clipper > ducking osis > ducking clipper > spinning osis > osis > diving clipper > weaving clipper > zulu clipper > diving clipper > weaving clipper > zulu clipper > gyro osis > gyro clipper > spinning clipper > gyro clipper > osis > xbody rake > xbody rake
Value: 74 Contacts: 23
2. Henry Griese(Stoughton, Winsconsin) - Spinning clip > gyro clip > osis>osis > spinning clip > gyro clip > diving clip > ducking clip > diving clip > ducking clip > spinning osis
Value: 34 Contacts: 11
3. Ken Somolinos(Japan) - gyro clip > diving clip > gyro clip > diving clip > ducking clip > spining clip > ducking clip > spining clip > ducking osis > osis > osis
4. Alex Urano(Melbourne, Australia)[/b] - Diving clipper > gyro clipper > diving clipper > gyro clipper > ducking clipper >spinning clipper > ducking clipper > spinning clipper
Value: 24 Contacts: 8
5. Mateusz Janicki(Leszno, Poland) - spinning clip>diveing clip>ducking clip>spinning clip>diving clip>ducking clip>osis>osis
6. Jeremy O'Wheel(Hobart, Tasmania) - diving clipper > ducking clipper > diving clipper > ducking clipper > spining clipper > spining osis
Value: 19 Contacts: 6
7. Nic Bathgate(Dunedin, New Zealand) - Osis > ducking clipper > spinning clipper > ducking clipper > osis
Value: 15 Contacts: 5
8. Chris May(Medford, OR, USA) - Ducking Clipper > Ducking Clipper > Diving Clipper > Osis
Value: 12 Contacts: 4
9.
10.
Double Dexing(Must be Guiltless)
1. Kevin Regamy(Edmonton, Canada) - Pixie Legover > Atomic Legover > Pixie Legover > Atomic Legover > Pixie ss Legover > Atomic ss Legover > Pixie ss Legover > Atomic ss Legover > Pixie pickup > Atomic pickup > Pixie pickup > Atomic pickup > Pixie ss pickup > Atomic ss pickup > Pixie ss pickup > Atomic ss pickup > Smear > Atomsmasher > Smear > Atomsmasher > Pixie ss Mirage
Value: 53 Contacts: 17
2. Jeremy O'Wheel(Hobart, Tasmania) - Ripwalk > blur > parkalk > sidewalk > shmoe > magellan > smear > pixie ss mirage > magellan > smear > pixie ss mirage > pixie switch > pixie switch > tap > atomsmasher > tap > atomsmasher
Value: 57 Contacts: 17
3. Mateusz Janicki(Leszno, Poland) - Shmoe>assasin>magellan>smear>dimwalk>sidewalk>ripwalk>sidewalk>ripwalk>stepping op legover>parkwalk>blur>pixie legover
Value: 47 Contacts: 13
4. Chris May(Medford, OR, USA) - Magellen > Smear > Toe Barrage > Paradon > Double legover > Double Over Down
Value: 20 Contacts: 6
5.
Tripple Dexing(Must be Tripless)
1. Ken Somolinos(Japan) - frantic butterfly > blurry dlo > pixie eggbeater > pixie dlo > paradon swirl
Value: 23 Contacts: 5
2. Jeremy O'Wheel(Hobart, Tasmania) - Fog > smog > pixie tap > dominatrix
Value: 18 Contacts: 4
3. Michał Biarda(Warsaw, Poland) - Sailing Legover > Frantic Legover > Smog > Pixie Tap
Value: 16 Contacts: 4
4. Chris May(Medford, OR, USA) - Pixie Barrage > Pixie Paradon
Value: 9 contacts: 2
5.
Toe Run(Must be Tiltless)
1. Michał Biarda(Warsaw, Poland) - Toe Blur > Smudge > Smear > Plo > Smear > Plo > Magellan > Pixie ss Mirage > Magellan > Pixie ss Mirage > Symposium Pixie > Symposium Mirage > Symposium Pixie > Symposium Mirage > Ducking Legover > Ducking Legover > Ducking Mirage > Diving Legover > Weaving Legover
Value: 58 Contacts: 19
2. Jeremy O'Wheel(Hobart, Tasmania) - Fairy ss mirage > fairy ss mirage > smear > pixie ss mirage > smear > pixie ss mirage > magellan > pixie switch > magellan > pixie switch > tap > atomsmasher > tap > atomsmasher > atomic legover > smog
Value: 51 Contacts: 16
3. Tobias Djiuardi(Auckland, New Zealand) - Smear > Mirage > ATW In > Datw In > ATW Out > Pixie Same Pickup > Pickup > Legover > Pixie > Pickup > Magellan
Value: 26 Contacts: 11
4. Jake Raye(Chicago, IL, USA) - smear > double switchover > atom smasher > atom smasher > fairy smasher > mirage > leg over
Value: 21 Contacts: 7
5.
Clipper Run(Must be Guiltless)
1. Mateusz Janicki(Leszno, Poland) - spinning clip > ducking clip > ducking clip > sidewalk > ripwalk > sidewalk > ss butterfly > ripwalk > whirl > osis > osis > ss butterfly
Value: 40 Contacts: 12
2. Henry Griese(Stoughton, Winsconsin) - Ripwalk > infinity > infinity > ripwalk > diving clip > ducking clip > diving clip > ducking clip > spinning clip > osis > spinning clip > osis
Value: 38 Contacts: 12
3. Chris May(Medford, OR, USA) - Barfly > Barfly
Value: 8 Contacts: 2
4.
5.
Unique Delays
1. Kyle Moery(Michigan, USA) - head>l shoulder>r toe>forehead/face>r shoulder>r inside>clip>op outside>toe>back>l inside>clip>op outside
Contacts: 13
2. Henry Griese(Stoughton, Winsconsin) - Clipper > op outside > same toe > same inside > op inside > same toe > same outside > op clip > head stall > neck stall > shoulder stall > mouth stall
Contacts: 12
3. Janis Lesinskis(Melbourne, Australia) - outside>op inside>op inside>op outside>same pincher>op pincher>same knee>op knee>same toe> op toe>neck stall
Contacts: 11
4. Nic Bathgate(Dunedin, New Zealand) - side stall > op side stall > op toe > lap stall > toe > clipper > clipper > back stall
Contacts: 8
5.
Unique Sets(Must be Guiltless)
1. Serge Kaldany(Paris, France) - fear > toe blur > fear > toe blur > smear > atomsmasher > smear > legbeater > ripwalk > stepping legover > pixie tap
Value: 43 Contacts: 11
2. Michał Biarda(Warsaw, Poland) - Fairy Clipper > Stepping Far Legover > Quantum Legover > Plo > Quantum Legover > Plo > Atomsmasher > Atomsmasher
Value: 26 Contacts: 8
3. Jeremy O'Wheel(Hobart, Tasmania) - Matador > ripwalk > blur > assassin > pixie switch > pixie switch > atomsmasher > tap
Value: 30 Contacts: 8
4. Nic Bathgate(Dunedin, New Zealand) - Fairy clipper > blurry clipper > spinning clipper > blurry clipper
5.
Unique Symps(Must be Guiltless)
1. Shane Smith(Auckland, New Zealand) - Little Apple > Symposium ss mirage > Dolimite > PS Mirage > Symposium Mirage > Symposium ss DLO > Symposium ss Mirage > Blackula
Value: 31 Contacts: 8
2. Jeremy O'Wheel(Hobart, Tasmania) - Whirlygig > beta blur > beta smear > symp mirage > witchdoctor > symp whirl
Value: 27 Contacts: 6
3. Chris May(Medford, OR, USA) - Symp ss mirage > Symp Mirage > Flail > Symp Whirl
Value: 13 Contacts: 4
4.
5.
Unique Downtime(Must be Tiltless)
1. Jeremy O'Wheel(Hobart, Tasmania) - Barrage > paradon > drifter > whirl > drifter > whirl > down double down > butterfly > pdx mirage > butterfly > pdx mirage > paradon
Value: 39 Contacts: 12
2. Mateusz Janicki(Leszno, Poland) - Toe Barrage > Butterfly > PdxMirage > Mirage > ssMirage > Legover > Illusion > Butterfly > PdxMirage > Osis > Osis
Value: 31 Contacts: 11
3. Henry Griese(Stoughton, Winsconsin) - butterfly > pdx mirage > butterfly > pdx mirage > mirage > legover > mirage > legover > drifter
Value: 23 Contacts: 8
4. Chris May(Medford, OR, USA) - Paradon > PS Mirage > Paradon > PS Mirage
Value: 14 Contacts: 4
5.
If you can think of improvements you would like to see made to the running of this competition please pm me about it.
Fun Events:
Best Unique Strings
9.
10.
5.
5.
5.
4.
5.
Unique Delays
Contacts: 13
Contacts: 12
Contacts: 11
Contacts: 8
5.
5.
4.
5.
5.
The competition is to have the most contacts!! (so no limit )
Toe shuffle is when you do toe moves with an uptime and downtime dex:
so something like - smear>fear>tap>toe blur etc. - not just general toe moves.
I'll go try to set records for all the events now! If I'm quick I can hold the "dexless shred" for a few minutes (until somebody notices my name at the top and realises how embarressing that is for everybody else )
Sorry for the double post - quick question.
With "unique double dex" - are we just talking moves with 2 dexes? Or are we talking moves with two dexes done in one action on the same leg - ie paradon>barrage>double swtich over?
I tend to think of "double dex" moves as the latter - but the description suggests the former...
Huzzah - triple post
I realise Ken has flogged my dexless. I had a go at most of the things though and here are my results:
Dexless:
dive clip>duck clip>dive clip>duck clip>spin clip>spin osis (I've hit that with osis>osis at the end before but I think results should only count if they were done after the comp...)
score: 19 Contacts: 6
Double Dex (presuming it just needs to be moves with 2 dexes)
Ripwalk>blur>parkalk>sidewalk>shmoe>magellan>smear>pixie ss mirage>magellan>smear>pixie ss mirage>pixie switch>pixie switch>tap>atomsmasher>tap>atomsmasher.
Score: 57 Contacts: 17
Triple Dex
Fog>smog>pixie tap>dominatrix
Score: 18 Contacts: 4
Toe Shuffle
Fairy ss mirage>fairy ss mirage>smear>pixie ss mirage>smear>pixie ss mirage>magellan>pixie switch>magellan>pixie switch>tap>atomsmasher>tap>atomsmasher>atomic legover>smog.
Score: 51 Contacts: 16
Symposium
Whirlygig>beta blur>beta smear>symp mirage>witchdoctor>symp whirl
Score 27 Contacts: 6
Unique set
Matador>ripwalk>blur>assassin>pixie switch>pixie switch>atomsmasher>tap (I hope pixie set and pixie ducking set count as uniques )
Score: 30 Contacts: 8
Downtime
Barrage>paradon>drifter>whirl>drifter>whirl>down double down>butterfly>pdx mirage>butterfly>pdx mirage>paradon.
Score 39 Contacts: 12
I could defintily beat most of those but didn't want to spend too long on each. Also I wrote out the combos so in some instances I could easily have hit a move with a higher add value but didn't because it would have made it impossible to link the next move (which I didn't hit)
Dexless:
Triple Dex
Toe Shuffle
Symposium
Unique set
Downtime
Jeremy - double dexing and tripple dexing mean any unique move that involves 2 or 3 dexes respectively. (eg for doubles: fear>dlo>butterfly swirl>spanishfly>blurry torque)
Thanks for pointing out what toe shuffle actaully means, changed name to 'toe run'.
Does anyone think I should make toe run guiltless? I just made it tiltless because there are alot more moves you can do that are tiltless on toes than you can on clippers :s.
There is no limit on contacts...
Thanks for your entrys guys! You are really great at participating in these things! Props for that!
Updating now...
Updating now...
Right rankings are updated!
Congratulations Ken and Jeremy on your placings! I will endevour to get some records tomorrow to put up! The only one I probably wont do will be symp lol.
Do you think that the value for double and tripple dexing should be total dexes instead of total adds? Are tripple dex clipper moves really harder than triple dex toe? I think toe are harder? So maybe the value should not be measured in adds? I dunno.
Clarification on Unique sets event:
The uptime component of any move is counted as a set.
The only set's disallowed are normal toe and clipper sets.
Ducking and diving are counted as set components they must be included with another legal set (ie not just toe or clipper) to be counted as a unique set.
example:
These sets are unique: pixie, pixie ducking, spinning, spinning ducking etc.
Ducking and Diving when not combined with another set are counted as downtime components.
I hope that clears that up
example:
Dexless
Spinning clip>gyro clip>osis>osis>spinning clip>gyro clip>diving clip>ducking clip>diving clip>ducking clip>spinning osis
11 contacts
34 points
Unique delays
Toe>toe>clipper>clipper> x body toe
5 contacts
8 points
Clipper run>
Ripwalk>infinity>infinity>ripwalk>diving clip>ducking clip>diving clip>ducking clip>spinning clip>osis>spinning clip>osis
12 contacts
38 points
11 contacts
34 points
Unique delays
5 contacts
8 points
Clipper run>
12 contacts
38 points
Ok sam, I guess we both have different opinions on the matter, I think that [set, component] implies its oposite leg (eg fairy mirage = fear) you think different, its not a problem.
Let's try to keep this thread to competition related discussion, if you are still unhappy please PM me about it and we can discuss it on msn or something .
Just you wait Jeremy! Ill whip out some badass links tomorrrow!
- enhancement
Flail>Symposium Mirage>Backside Smear>Symposium Frantic Legover (Spasm)>Symposium Reverse Whirl
EDIT:Hit Today
Flail>Symposium Mirage>Backside Smear>Symposium Reverse Whirl>PS Mirage>Symposium Pixie>Dolimite
Tobias;
Toe Run
Smear>Mirage>ATW In>Datw In>ATW Out>Pixie Same Pickup>Pickup>Legover>Pixie>Pickup>Magellan
EDIT:Hit Today
Tobias;
Toe Run
- shreddaily
- Flower Child
first california session produced:
(dexless)
(left foot clip)spinning ducking clipper>inspinning clipper>spinning clipper>inspinning clipper>spinning osis>ducking clipper>ducking osis>ducking clipper>spinning osis>osis>diving clipper>weaving clipper>zulu clipper>diving clipper>weaving clipper>zulu clipper>gyro osis>gyro clipper>spinning clipper>gyro clipper>osis>xbody rake>xbody rake
23
(dexless)
23
- mosher
- brutal footbag cronie
Hah!! it doesn't count for best clipper run! I still have a chance!shreddaily wrote:first california session produced:
(dexless)
23
