SALE: Advice on Improving
Ill tell you what you need to know to improve your footbag game for 1 dollar. Ask me a question, as in depth as you like, and I will give you an answer that is sufficient to you or you pay me nothing. Who wants to ask me the first question? Think about it b/c it'll cost you a dollar if I respond to it to your satisfaction!
- hakkpakk
That aint a good idea
Dan Haritan
http://www.myspace.com/dannyspade
Check out my beginners blog:
http://modified.in/footbag/viewtopic.php?t=15533
My first vid: http://fizzied.phasing.org/2%3F12%3F07.mov
- SandWraith
I'll paypal you a buck if you answer my question well.
blog
blog
To answer Zach Marine's question:
Improving string length requires several requisite skills that you may or may not have. Please do down this list to determine whether you are missing any of these skills:
Do you have:
- good control of your "foundation" moves?
- the ability to hit most moves and control the position and speed of the sets out of those moves?
-can you use both legs to hit many or most of your moves?
- the ability to maintain an even pace while linking tricks?
- the stamina to air bag for 60 seconds at a time without keeling over?
- the ability to breathe fairly consistently while shredding, or do you hold your breath through most of your tricks?
- a wide variety of tricks you can consistently hit (8/10 times)?
- a few tricks that you can hit with COMPLETE confidence?
- the motivation to stop trying big tricks for a month or so to concentrate on improving your run length?
* I reserve the right to add to this list if I think of any other relevant skills.
If you have answered no to one or several of these questions, then you know what you have to work on. If you have answered yes to these questions, then you already have the skills to hit long runs. You just need focused practice and some advice.
Here is some advice:
Firstly, dont play above your level. Trying tricks that you only hit once in 3 tries is a sure way to end your runs prematurely.
Secondly, do a good mix of tricks, using both legs so as not to tire one leg out more than another.
Thirdly, anytime you feel out of control, fall back on one or several of your easiest tricks (i.e., bails for you) until you have regained control. These fall-back tricks should be tricks that you have complete confidence in, so that if you dropped them, it would be a fluke.
Fourthly, develop combos and links of 3-4 tricks that feel natural to you.
Fifthly, pace yourself.
Sixthly, never allow the footbag to leave your foot until you are ready to set the next move. If you end a move with poor balance or if the move is completed in such a way that your stall is uncontrolled, your next trick will become infinitely harder.
Seventhly, you may wish to incorporate drill-like patterns of moves mid-run if you run out of ideas (i.e., butt>pdx mirage>op butt>pdx mirage). Some people discourage this in true shred, but for run length, it may be a good idea.
Eighthly, rmember to breath, because as you expend your o2, you'll need more. Breathe esp. during the tricks that are easiest for you.
Ninthly, spend at least 20 minutes of each session practicing your run length, although NOT ALL AT ONE TIME. I like to warm up with about 5-10 minutes of runs, and then I usually warm-down the same way. Sometimes, I practice run length mid-session, but definitely not throughout the whole session. My body needs a break.
Hope you get something out of this,
Do you have:
