Stainless Steel Filler (Price Drop!!) !!IN STOCK!!
This is for footbag related items only.
Brad Benson
Post by Brad Benson » 04 Sep 2009 12:26
UPDATE::: Everyone liked this filler so much I had to get some more. I got a bigger shipment this time and it made it a little cheaper. It is now $6 per pound, plus $5 for shipping in the US. Contact me for orders outside the US.
This is my favorite filler for my footbags. It is 409 stainless steel. It is magnetic and has a good resistance to corrosion and of course non-toxic. This stuff is MUCH better than steel filler and is a little heavier than steel, and safer than lead. The particles are in the range of 2mm in diameter, as you can see in the pic, some are a little smaller. They are flat little disks that are around 1mm thick. I threw a BB gun BB in the pile for a size comparison.
Most people mix seed beads or plastic pellets or something with there lead or tungsten to get the fill amount with the weight they want. With this filler all you have to do is fill it to the weight you want and that is usually the fill amount you want. When I use this filler in a bag, that is all I use in the bag. You end up with a bag that feels about like sand but is as heavy as a metal bag and because it is only one uniform filler it plays very consistent.
will_T
Post by will_T » 07 Sep 2009 13:26
Strange looking fill, that's for sure. If anyone with lots of experience using different fills can vouch for this stuff, I might buy some from you. My only concern is that they might slip through bleed holes.
Anyone?
Brad Benson
Post by Brad Benson » 08 Sep 2009 05:35
I have not had any problems with it leaking out of the bags
Toasty
Post by Toasty » 15 Sep 2009 04:40
Looks interesting. I may consider buying some.
Brandin Sharp Image
will_T
Post by will_T » 18 Sep 2009 13:34
i received some of this from brad yesterday. i filled a bag to 60 grams and a mini to 55 grams with this stuff and they are quite nice. the sound the bags make is interesting as well, it's very muted. less bouncy than my tungsten/pellet bags too, and much cheaper.
i recommend picking some up
EDIT: the type of steel used is selected for its resistance to corrosion. citation: "Its applications are those where appearance is a secondary consideration to mechanical properties and corrosion resistance"
basically it's used because it may not be shiny, but it's corrosion resistant. link: http://www.azom.com/details.asp?ArticleID=969
WyrmFyre
Post by WyrmFyre » 21 Sep 2009 23:31
Could you ship this to the UK, and if so how much would that be?
Ian Cozens
My FootBlog :: PureShred
Brad Benson
Post by Brad Benson » 22 Sep 2009 05:15
I can but I am not sure how much it will cost. PM me your address and how much you want and I will find out for you.
Brad Benson
Post by Brad Benson » 01 Oct 2009 09:18
Enough people liked this stuff I got more this time which made it cheaper so check out the updated post above.
Toasty
Little pieces of Heaven.
Post by Toasty » 01 Oct 2009 18:39
Brad, I just want to thank you again for the this absolutely wonderful filler! I used it in a new bag I stitched today, and it is like there are little pieces of Heaven in my bag. As Will said, the sound is very muted when kicked, which I really like as well. I'm definitely going to order another pound.
P.S. Before this filler, I was still using 4.5mm BBs.
Brandin Sharp Image
will_T
Post by will_T » 15 Oct 2009 19:28
bump: this stuff's off the heezy. buy some and help brad out :) it's all i use now.
Donovon
Post by Donovon » 01 Jan 2010 20:31
Bump.
I got a chance to check some of this stuff out from Brian @ NYJ. This stuff is sooo sweet. Tried to get my hands on some but he wont order anymore unless others want to chip in.
Consider me in the next buy.
~Donovon
Brad Benson
Post by Brad Benson » 04 Jan 2010 06:42
Donovon, you are definitely going to be the first to get some on my next order.
Anyone interested in getting some of this, let me know so I can get a list together. Once I get 9 more pounds sold I will order more. I have to order quite a bit to get a decent price.
will_T
Post by will_T » 05 Jan 2010 13:51
i'll be keeping an eye on this thread, brad. i've still got about 2 pounds from your last shipment, if i start to run low when you've got more buyers i'll chip in on your next order. happy 2010 :)
Brad Benson
Post by Brad Benson » 18 Jan 2010 07:24
THE SHIPMENT IS ON THE WAY. I got enough orders to get another large shipment to keep the $6 per pound price for everyone. PM me if you want any.
Brad Benson
Post by Brad Benson » 02 Feb 2010 12:22
The filler shipment is here and ready to go. Everyone that got in on the order has already had there request shipped out as they did get first dibs on what they wanted since they all helped to make it possible to get another large shipment. If anyone else wants to get there hands on some of this great filler let me know.
Post by Wasabi » 30 Sep 2011 13:36
Hey Brad, I could use 10-20 pounds of this s/s fill. Not sure if you still surf modified and such, but you can contact me via my full name with a period in the middle @gmail.com.
I'll try to contact you in other methods as well. I also have Paypal and whatever.
Brad Benson
Post by Brad Benson » 30 Sep 2011 13:58
Wasabi wrote:Hey Brad, I could use 10-20 pounds of this s/s fill. Not sure if you still surf modified and such, but you can contact me via my full name with a period in the middle @gmail.com.
Shoot me a PM. Don't know your full name so I can't email you. I did PM you though.
billyg
Post by billyg » 10 Oct 2011 17:10
Do you make these yourseld? If so how? Don't worry. I'm not planning on making my own. I have no metalworking experience whatsoever, but I'm quite curious.
billyg
How much do you have in stock right now?
Brad Benson
Post by Brad Benson » 10 Oct 2011 17:36
I have 10 pounds I could ship tomorrow and I can get more anytime.
