by Muffinman » 23 Feb 2006 04:39
Th3jermster
PostPosted: Sat Dec 04, 2004 2:18 pm Post subject: leg overs step by step Reply with quote Edit/Delete this post Delete this post View IP address of poster
want it try leg overs i seem to be too slow i only landed one once and i still do get it but ya can some one tell me how to do a leg over and pick ups step by step ? oh ya and do leg overs need lots of speed thank you, jeremy
Back to top
View user's profile Send private message Send e-mail AIM Address
B_Man
PostPosted: Sat Dec 04, 2004 3:35 pm Post subject: Reply with quote Edit/Delete this post Delete this post View IP address of poster
Legovers are like punctuation - the more you practice the more naturally it comes. Not only does a proper Legover lead to new, more exciting tricks (such as Illusion, and further down the road, Eggbeater) but proper punctuation can lead to new, more excititing jobs through proper resumes!
The first step to Legovers is you need a good solid beginning - a toe delay where you aren't shaky and off balanced. This is much like a sentence where if you start with a capitalized letter it doesn't not make the reader off balance and shaky followed by whatever it is you are trying to communicate. In Legover's case, that solid 'n balanced toe stall is followed by a hop off the support foot as you set the bag upwards. You then go over from out - in with the "jumping" leg and you catch it on the same toe as you land on the other foot.
And there you have it! Isn't life in a nutshell exciting? Weee!
PS - No offence ment by ripping on your punctuation. It's all in good fun Very Happy
_________________
- Byrin Wylie
SlashC wrote:
mosher wrote:
Freestyle is just an afterthought?
I suggest not even including it.
Well for all the eastern shredders that came to shredmonton last year... (zero) it might as well be a net only event Wink .
PWNED.
Back to top
View user's profile Send private message Send e-mail Visit poster's website MSN Messenger
Wim
PostPosted: Sat Dec 04, 2004 3:37 pm Post subject: Reply with quote Edit/Delete this post Delete this post View IP address of poster
No, it's not a speed thing! The main thing to remember is timing.
Say you're trying a leg over set from the right foot. Set the bag straight up (about knee high). BEFORE the set foot lands, hop off the left foot so you're up in the air with both feet for a split second. THEN from the moment your dex leg is off the ground, start the dex with the calf or the ankle, as you prefer.
By this time you have completed a SUPER-CLEAN legover!!!
The same timing applies to a pick-up, but the dex direction is reversed.
Let us know how it gets along!
_________________
Wim Van Verre
-Brussels Footbag Club-
Bllllog-Challlengiz-Org gallery
Back to top
SlashC
PostPosted: Sat Dec 04, 2004 5:01 pm Post subject: Reply with quote Edit/Delete this post Delete this post View IP address of poster
Here's how I do a legover:
1) Set the bag up to about thigh height
2) While the bag is on the way up, plant the setting foot as quickly as possible. It's not a stomping kind of plant. Try to touch down swiftly with the front part of the foot. The important thing is to maintain balance.
3) As the bag approaches the zenith bring the dexing leg up and to 45 degrees pointing towards the ground. It's hard to describe this position without a picture. Imagine it like this: right knee knee bent at 90 degrees with foot pointing down to the ground. Now move the lower part of the leg 45 degrees to the left. The knee will be pointing away from the body.
4) Spot the bag at the apex. It should be ideally just inside the little crook between the knee and the shin.
5) Swing the leg around the bag continuing the out to in motion all the time picturing the downward vector of the bag (what was just spotted in step 4).
6) As the bag descends towards the ground complete the dex by moving the foot in under the bag and gently cushioning it with both the delaying leg and by bending the supporting knee. It also can help to slightly hop off the supporting leg as the bag is delayed (pretty much the same as bending the supporting knee).
And with a couple minor changes here's how to do a pickup (steps 1,2,6 are the same as legover):
3) As the bag approaches the zenith bring the dexing leg up and to 45 degrees pointing towards the ground. It's hard to describe this position without a picture. Imagine it like this: right knee knee bent at 90 degrees with foot pointing down to the ground. Now move the lower part of the leg 45 degrees to the right. The knee will be pointing inwards towards the body.
4) Spot the bag at the apex. It should be ideally just outside the little crook between the knee and the shin.
5) Swing the leg around the bag continuing the in to out motion all the time picturing the downward vector of the bag (what was just spotted in step 4).
_________________
Rory ("Floss Son!") Dawson
"You can ask a stranger, my legs is fast and danger!"
"If you had phalli of the left and right persuasion... which would you copulate with?"
- Dr. B Suess
Buy ShrEdmonton Shirts!
Back to top
View user's profile Send private message Send e-mail Visit poster's website AIM Address MSN Messenger
Wim
PostPosted: Sun Dec 05, 2004 5:14 am Post subject: Reply with quote Edit/Delete this post Delete this post View IP address of poster
All of this is true. Smile
As to my previous post, I'd like to add that you can also set & start the dex simultaneously. In other words: you'll be pretty much using the upward power of your support leg for the set & not the set foot (you need to bend the support leg slightly to gather enough force for this).
Sounds weird? That's how I do legovers n pickups these days; IMO the easiest way.
_________________
Wim Van Verre
Back to top
FootBaGGeRKiD
PostPosted: Wed Dec 08, 2004 8:44 pm Post subject: Reply with quote Edit/Delete this post Delete this post View IP address of poster
when i do legovers the bag hits my calf usually on the dex, but when it doesn't i can't get my leg under it in time
_________________
KyLe HiLdEbRaNd
- Boulder, Colorado -
Back to top
SlashC
PostPosted: Thu Dec 09, 2004 12:35 am Post subject: Reply with quote Edit/Delete this post Delete this post View IP address of poster
Just keep practising. Repitition will build the muscle memory, will make it easier and easier each time you try it.
_________________
- Dr. B Suess
Back to top
Wim
PostPosted: Thu Dec 09, 2004 4:49 am Post subject: Reply with quote Edit/Delete this post Delete this post View IP address of poster
@footbaggerkid:
perhaps your dexes are too wide? Make sure you set the bag close to your body, almost from under you (but not completely, you don't want to hit that other sack). The bag shouldn't be more than a foot away from you.
_________________
Wim Van Verre
