Double Pickup
Double Pickup
Double pickup
SET >> OP IN [DEX] > SAME IN [DEX] > SAME TOE [DEL]
Some tips for toe set double pickup would be appreciated, thx in advance '
edit: I've footed this a bunch of times.
edit2: hit now
edit3: fixed jobs
edit2: hit now
edit3: fixed jobs
- Spontaneous Spaz
Can either of you hit double pickup?
What really helps with double pickup is working toe barrage. Toe whirls also help.. Because pickup dexes are like whirls. Start the first dex like a half whirl and just go right into the 2nd
- Zeb Jackson
thanks henry this helped me alot, i footed it twice today, and up until then i havent even tried it
-Zeb Jackson
http://www.elitefootbag.com
Thx Henry, one question, are both dexes whirl like? I've been trying this with first dex whirl like (peaktime) then second dex atw like (downtime), in any case I'll school toe barrage more.HenryG wrote:What really helps with double pickup is working toe barrage. Toe whirls also help.. Because pickup dexes are like whirls. Start the first dex like a half whirl and just go right into the 2nd
I think learning double around the world is really important. I don't think you necessarily need to know how to toe barrage, but that would make double pickup really easy. I think the most important thing is getting your set foot down really fast, dexing the bag at the apex for the first one, and setting the bag to about your knee. I think I might lean back sometime too, but that is proabbly just bad form.
Tom Stepek
I hit it like a whirling pickup with the whirl done mid time.
- beenjammin
