Australiasmokefree wrote:what country is that 10 dollars from? The light friggin shines right through it.
hey,
from my experience, they break in quite quickly and very evenly, the panels are big which helps, but the bag is still golfball size and very playable. i love shreding with them because the larger panels make for a very soft and easy landing on your foot. they also break in very round (no deformities). i'd say after 1-3 sessions depending on how hard you shred, they would be broken in. if your including hand messaging and kicking though it could be done very quickly.
They range from 55-60 grams (steel shot).
OsbBag
need I more gathering? help mee
weight: 55g(3g plastics balls+47g lead balls) ; size: 4.2cm (diameter)
thanx
thanx
Bags For Sale! -20eur
Jozef PalenÄ
Jozef PalenÄ
I agree with Tom, You don't need more gathers. I think its very nicely stitched and it is pretty.
Mark Telman
TechnoKicks Footbag Stitcher
Back to Custom Orders! $15
Stitch until you bleed then stitch one more bag
then Kick til you fall down
- PegLegHolly
- Swashbuckler
- Eskimo Joe
- Cold Blooded
did you try the bigger pellets?? the Problem with the seed beads is they have a hole and they will break and cut the bag from the inside out. CR craft has 2 - 3 mm glass pellets you might want to try them.
I like the look very nice bag.
Mark Telman
edit: ugh. last post on page, and this is a pretty one. moved to next page.
