looking for a 2 panel pattern
hi everybody.i am looking for a 2 panel pattern.i'll be very happy if you can help me.thanks in advance.
http://www.pjb.com.au/jug/leatherballs.html
2 to 20 i think. good luck!
I believe it's better to use other types of fabric other than facile for lesser paneled bags. At least below 14 panels, but that's just me.
2-panels are pretty hot.
Im my mind 2 panels aren't the easist to stich as your always stiching on a curve... I've only made 2 and they are the best beginner bags epsh filled with 1mm bear shot as there floppy and still set alright-ish lol
as for the using facile or not thing... mine are both facile but only cos I had it to hand and have a fair bit of it left but something like a mircosuede (with the coated back) would work just as good
that bag does look sweet though man, props to you my friend
- Drew Hamilton
- Drew Hamilton
- vettehunter123
Here's how I do it.
Make a "T" with your panels and have the good sides of the facile facing in toward each other.
Stitch as even as you can in a curve as you line the panels edges up.
Should look something like that.
Make sure your gather is even and not too tight (like mine
Looks like a potty
Keep going...
Keep stitching in a curve, then flip it for the blind stitch and fill it with some homemade goodness.
Now go show your funky 2 panel to all of your hacky sack friends! Woo hoo!
Looks like a potty
Travis Iden
- Drew Hamilton
- bluntobj3ct
- vettehunter123
