Stablilzer Muscle Strengthening
- Sporatical_Distractions
- registered sacks offender
Any at home methods of strengthening stabilizer muscles?
and don't say the obvious play more footbag.
- StyleeRiley
Re: Stablilzer Muscle Strengthening
I've got some good ones for ankles if you are interested.Sporatical_Distractions wrote:Any at home methods of strengthening stabilizer muscles?
definitely. that's wat this thread is all aboutjanis wrote:I've got some good ones for ankles if you are interested.
Perhaps narrow down the part of the body you are talking about??? (ankles, calves, quads, hams, core ....)
But short answer... lift heavy.
Jon's FootBlog
MSN: jon.haber@gmail.com
- beenjammin
- StyleeRiley
Cruising arround on the snow for a day (I don't care how, as long as its not on a sled) definitely works the stabilizer muscles of the legs. My snowshoeing expedition last Monday left my ankles begging for more. I was still feelin' it on our Wednesday shred, but in the long run it makes for better feet. I know it's no home exercise, but it's really effective.
I don't know if this falls under "strengthening", but it helps balance if that's what you're looking for. Close your eyes and grab on ankle like your stretching your quads. So basically you are standing on one foot with your eyes closed. It's harder than it sounds.
Ben Skaggs
Squats, Deadlifts, Bench Press, and Military press will all build stabilizer muscles because they work the entire body, taxing more muscle fibers then any other movements.
You don't need to lift heavy at all, just enough to build muscle fibers. For a footbagger, aim for high reps to build endurance. If your goals are size and strength, lower reps and heavier weights are necessary. In addition, remember that if if doesn't hurt (in a good way), your not helping yourself.
bodybuilda
Sorry to pick apart some of this post because the first part is very correct.
I don't even understand this sentence. Heavy is a relative term. To build stabilizing muscles going heavy (again a relative term) for you (something in the 4-12) rep range will get the stabilizers going. For larger muscles groups such as your legs working exercises with a barbell is great but for smaller muscles groups doing dumbell exercises are great (again I am talking about when you are trying to target stabilizer muscles - your best bet is to mix up your exercises and hit all muscles groups from a variety of angles with different exercises using free weights (barbell/dumbbell) and cables/machines. I really just don't understand the statement "just enough". Perhaps I just misunderstand.Maraxus wrote:You don't need to lift heavy at all, just enough to build muscle fibers.
This is not correct. Pain, delayed onset muscle pain, ect is a poor indication of how well the exercise worked. Everyone is different and some people will never experience pain while others will experience a lot.Maraxus wrote:Remember that if if doesn't hurt (in a good way), your not helping yourself.
Jon's FootBlog
I apologize for not clarifying. Just enough is a very broad statement, and what I meant by it was a - suitable amount of resistance weight for the given person, in order to enable fast twitch muscle growth. The exercises I have listed were just a few key lifting movements that target more then a single muscle group. Dumbells and modified versions of each of these exercises are just as good depending on a given person's goals, but those goals can only be realistically set by themselves. Like you said, Jon, everyone is different.I really just don't understand the statement "just enough"
Another bold statement I suppose, I agree with what you are saying but only to the extent of improper form or too much weight straining the body in an unnatural way.This is not correct. Pain, delayed onset muscle pain, ect is a poor indication of how well the exercise worked.
I disagree when the muscle pain relates to strength training in order to enable muscle growth. Pushing yourself beyond what your body is accustomed to is necessary for strengthening muscle bodies and achieving levels of strength and endurance you never had before.
bodybuilda
I dont know anything about fitness stuff. Do stabilizer muscles help overall balance in any way, or does it all have to do with the inner ear.
Mike Faille
http://www.mikefaille.com
Imagine yourself doing a bench press. The active muscles make the bar move up and down, and the stabilizers keep the bar from moving around in the horizontal plane (sideways, ect).
This generalizes to any motion that your body makes. Stabilizer doesn't refer to a specific group of muscles.
Janis, what the hell was that? You tease!
Colin Kennedy
ckennedy@footbag.org
I think having some weight held in each hand while doing two legged leaps over a plastic shipping crate, done horizontally, helps for good balance that you don't ordinarily feel from jogging or footbag. Both feet must leap and land at approximately the same time, I believe.
I compiled a set of ankle exercises here:
http://modified.in/footbag/viewtopic.php?t=16555
