Well this is getting easy...
5 op clippers done
100 op toe stalls done
200 alternating inside kicks done hard...
ATW in to out -> ATW out to in for one side so far
10 ATW pixie
hit pick-up BS
hit butterfly BS
hit mirage BS
hit legover BS
15 SS toe stall BS
Mirage -> Mirage -> opp foot -> rpt
30 kicks with left leg
Challenge JelloFootbags
- Hack Fiend
I footbag...because its freedom.
Zack Cizek
Big fan of Jorden Moir =D
Zack Cizek
What kind of tricks are you presently hitting? It's hard to challenge someone if you don't know what to challenge them against
If you are completely starting out...
ATW in to out -> ATW out to in, opposite foot, repeat.
Legover -> Mirage -> Legover -> mirage.
____
Edit..Reading your below post, I would extremely suggest you practise both feet right from the beginning. You'll thank yourself later
____
Jay Boychuk
- Hack Fiend
mabye give some of these a try
100 op toe stalls
5 legovers
10 ss clippers on both sides
5 op clippers
it would really help if you could edit the first post you made on the page to include a tricks that you are doing and that you would like to be challenged on. That way we can all give some better challenges
100 op toe stalls
5 legovers
5 op clippers
You should give a try to the challenge of jay, they'll help you get some consistency
And drill you left leg NOW
10 ATW pixie -> fairy -> rpt BS
hit pick-up BS
hit illusion BS
hit butterfly BS
hit mirage BS ( if not done )
hit legover BS ( if not done )
15 SS toe stall BS ( drill that left leg, if your able to do it BS try doing it setting higher than hip, even chest height will help you later anyway)
30 kicks with your left leg only ( your right too if your not already able )
you HAVE TO drill that left leg!!
I suggest you when you do rpt or drills, when you drops start back at the tricks you have drops so you always continue, as example if you try the challenge jay gave you : Legover -> Mirage -> Legover -> mirage.
right foot legover -> right foot mirage -> left foot legover ( drop )
than start back with the bag on your right foot and try the left legover again, until you got it
Same if you as example try doing 10 ATW, if you drop at 5 continue counting and start back at the end.
And always try to end your session on a good note, that way you'll be confident before you next session and it'll help you.
Oh and btw BS = Both Sides if you didn't know
And if you wan't better challenges, you should edit your first post to tell us, what you have hit, and what your current average run and good run are, that way'll we'll be able to challenge you a better way.
hit pick-up BS
hit illusion BS
hit butterfly BS
- Hack Fiend
Are all those written in your thread been hit? If not you should write which one you hit separately.
Here's some more challenge :
20 infinity
20 alternating clippers
20 SS clippers
legover> mirage > rpt ( try to get 12 contacts )
can you illusion? it's a nice donwtime component
if you can't, just hit it
if you can try : illusion > pick-up > rpt ( 12 contacts )
Hit osis if you haven't
Tells me if they're too hard.
20 infinity
20 SS clippers
