what moves to do?+Q
Challenge your friends to hit tricks/combos you know they can hit, even if they don't!
TCheas
what moves to do?+Q
Post by TCheas » 03 Aug 2011 00:21
So i need some of you guys to tell me what i should learn next ( or attempt XD)the level im at right now is i am perfecting clipper and im doing pretty good on ATW. toe inside outside dragon stalls are all solid.
also i had a question about this thing i was landing: its a clipper, then the support leg jumps to the side and the bag passes through the legs. i think its a set of some kind, ive been dying to know the name or if its even a real move...
WyrmFyre
Post by WyrmFyre » 03 Aug 2011 02:41
Sounds like stepping, which your right, its a set. Try adding another trick afterwards, like switch, or back to clipper :D
The moves you should be learning now are
ATWs, both directions and on both feet.
Switch
Pickup
Mirage
Illusion
And keep up the clippers too
Ian Cozens
My FootBlog :: PureShred
