(Current) Sets List
- bigdirtyfoot
- Sloppy
(Current) Sets List
Note: I couldn't edit Chris Holden's original post in the "Sets List 2004" thread so I figured I started a new thread... but if any moderators want to merge this into that thread, I guess that's fine.
So yeah I worked on this for about an hour or two because I noticed that Chris Holden's list wasn't edited or updated or anything. This includes all the sets that were posted in that thread, and I've organized them into (I think) better groups. Also, it's easier to read. Hope you all enjoy it. Feel free to add more sets, and I'll edit them in!
Components (Not Necessarily Sets):
1. Ducking
SET > DUCK [BOD] > (OP SIDE)
2. Diving
SET > DIVE [BOD] > (SAME SIDE)
3. Weaving (Ducking Same Side)
SET > DUCK [BOD] > (SAME SIDE)
4. Zulu (Diving Op Side)
SET > DIVE [BOD] > (OP SIDE)
5. Spinning
SET > (BACK) SPIN [BOD] >
6. Inspinning
SET > (FRONT) SPIN [BOD]>
7. Gyro (Setting foot does not plant on gyro except for symposium moves.)
CLIP > (BACK) SPIN [BOD] > (SAME SIDE)
8. Spyro (Planted Gyro) Used with symposium tricks.
Toe Sets:
1. Pixie
TOE > SAME IN [DEX] >
2. Fairy
TOE > SAME OUT [DEX] >
3. Wiggle (Pixie Fairy) (no plant while)
TOE > SAME IN [DEX] > SAME OUT [DEX] >
4. Atomic (Reverse Miraging Op Side)
TOE > OP OUT [DEX] > (OP SIDE)
5. Tapping (Reverse Miraging Same Side)
TOE > OP OUT [DEX] > (SAME SIDE)
6. Quantum (Miraging Op Side)
TOE > OP IN [DEX] > (OP SIDE)
7. Slapping (Miraging Same Side)
TOE > OP IN [DEX] > (SAME SIDE)
8. Terraging (Double Pixie)
TOE > SAME IN [DEX] > SAME IN [DEX] >
9. Sailing (Pixie Atomic)
TOE > SAME IN [DEX] > OP OUT [DEX] >
10. Frantic (Pixie Quantum)
TOE > SAME IN [DEX] > OP IN [DEX] >
11. Backside Symposium Frantic Pixie Symposium Quantum
TOE > SAME IN [DEX] > OP IN (no plant while) [BOD][DEX] >
11. Slaying (Beta Sailing/Pixie Symposium Atomic)
TOE > SAME IN [DEX] > OP OUT (no plant while) [BOD][DEX] >
12. Fusing/Falling (Fairy Atomic)
TOE > SAME OUT [DEX] > OP OUT [DEX] >
13. Double Fairy
TOE > SAME OUT [DEX] > SAME OUT [DEX] >
14. Sidewinding Fairy Gyro Barraging
15. Delusional (Double Atomic)
TOE > OP OUT [DEX] > SAME OUT [DEX] >
16. Wonton (Symposium Quantum)
TOE > (no plant while) OP IN [BOD][DEX] >
17. Flailing (Symposium Atomic)
TOE > (no plant while) OP OUT [BOD][DEX] >
18. Wontomic (Symposium Quantum Atomic)
TOE > (no plant while) OP IN [DEX] > OP OUT [DEX][XDEX] >
19. Phasing (Fairy Swirling)
TOE > SAME OUT [DEX] > OP BACK SWIRL [DEX] >
20. Surfing (Symposium Phasing)
TOE > SAME OUT [DEX] > (no plant while) OP BACK SWIRL [DEX][BOD] >
21. Gnome (Atomic/Tapping Swirling)
TOE > OP OUT [DEX] > OP SWIRL [DEX] >
22. Warped (Frontside Symposium Omelette/Flailing Atomic)
TOE > (no plant while) OP OUT [DEX][BOD] > OP OUT [DEX][XDEX] >
23. Floating (Reverse Warping)
TOE > (no plant while) OP IN [DEX][BOD] > OP IN [DEX] >
24. Swixie (Anti-Clipper Swirling)
XB TOE > SAME BACK SWIRLl [DEX] >
25. Moshing (Symposium Toe Swirling Stepping Set)
TOE>OP SWIRL>OP IN
Clipper Sets:
1. Stepping (Clip Set Miraging)
CLIP > OP IN [DEX] > (SAME SIDE)
2. Blurry (Stepping Paradox)
CLIP > OP IN [DEX] > (OP SIDE PDX)
3. Null (Stepping Atomic SS) (no plant while)
CLIP > OP IN [DEX] > SAME OUT > (SAME SIDE)
4. Pogo (Symposium Stepping) (Not a full dex, does not receive a symposium add.)
CLIP > (no plant while) OP IN [DEX] >
5. Hopping (Clip Set Illusion)
CLIP > OP OUT [DEX] >
6. Popping (Clip Set Symp Illusion)
CLIP > (no plant while) > OP OUT [BOD][DEX]
7. Nuclear (Clip Set Atomic)
CLIP > SAME OUT [PDX] [DEX] >
8. Quasi (Paradox Miraging)
CLIP > SAME IN [PDX] [DEX] >
9. Barraging (High Stepping)
CLIP > OP IN [DEX] > SAME IN [DEX] > (SAME SIDE)
10. Furious (Barraging Paradox)
CLIP > OP IN [DEX] > SAME IN [DEX] > (OP SIDE PDX)
11. Symposium Furious (Symposium Barraging Paradox)
CLIP > OP IN (no plant while) [BOD][DEX] > SAME IN [DEX] > (OP SIDE PDX)
12. Shooting (Stepping Paradox Illusion)
CLIP > (no plant while) OP IN [DEX] > OP OUT [PDX][DEX] >
13. Rifling (Stepping Double Switch Over)
CLIP > (no plant while) OP IN [DEX] > OP OUT [DEX] > SAME OUT [DEX] >
14. Sliding (Stepping Paradox Mirage)
CLIP > (no plant while) OP IN [DEX] > OP IN [PDX][DEX] >
Whirling/Swirling Sets:
1. Swirling/Burly
CLIP > SAME BACK/FRONT SWIRL [DEX] >
2. Smiling (Swirling Stepping)
CLIP > SAME (FRONT/BACK) SWIRL [DEX] > OP IN [DEX]
3. Whirling
4. Blazing
CLIP > OP IN [DEX] > (OP SIDE)
5. Flaring (Symposium Blazing)
CLIP > OP IN (no plant while) [BOD][DEX] > (OP SIDE)
6. Scattered (Reverse Whirling)
CLIP > OP OUT [DEX] > (SAME SIDE)
7. Shattered (Reverse Whirling)
CLIP > OP OUT [DEX] > (OP SIDE)
8. Blistering (Whirling Gyro)
CLIP > OP IN [DEX] > (BACK) SPIN [BOD] > (GYRO COMPONENT)
9. Clipper Reverse Whirling Spinning
CLIP > OP OUT [DEX] > (BACK) SPIN [BOD] >
10. Jolimont (Symposium Whirling Swirling)
11. Swirling Barraging
12. Revsteining (Double Reverse Swirling)
Spinning Sets:
1. Pyro (Pixie Gyro)
TOE > SAME IN [DEX] > (BACK) SPIN [BOD] >
2. Fyro (Fairy Gyro)
TOE > SAME OUT [DEX] > (BACK) SPIN [BOD] >
3. Sonic (Gyro Spinning)
CLIP > (BACK) SPIN [BOD] > (BACK) SPIN [BOD] >
4. Peeking (Double Gyro) (Peeking is set, spot the bag (like Osis), then spot the other way, thus peeking over your shoulder at the bag twice.)
SET > (BACK) SPIN [BOD] > (BACK) SPIN [BOD] >
5. Leaning (Stepping Inspinning)
CLIP > OP IN [DEX] > (FRONT) SPIN [BOD] >
6. Go-Go/Cubic (Stepping Backspinning)
7. Lateral (Atomic Backspinning)
TOE > OP OUT > (BACK) SPIN [BOD] >
8. Surging (Gyro Miraging)
CLIP > (BACK/FRONT) SPIN [BOD] > OP IN [DEX] >
9. Gyro Shooting (Surging Atomic)
CLIP > (BACK/FRONT) SPIN [BOD] > OP IN [DEX] > OP OUT [DEX] [PDX]
10. Slicing (Gyro Reverse Swirling)
11. Splicing (Gyro Symposium Reverse Swirling)
12. Twinspinning (Nuclear Inspinning)
CLIP > SAME OUT [DEX] > (FRONT) SPIN [BOD] >
13. Tapping Spinning
TOE > OP OUT [DEX] > (FRONT) SPIN [BOD] >
14. Neutron (Atomic Spinning)
TOE > OP OUT [DEX] > (BACK) SPIN [BOD] > (OP SIDE)
14. Radiative (Spinning Nuclear)
Unusual Sets:
1. Snapping (Dragon Set Swirling)
DRAGON > SAME FRONT SWIRL [DEX] >
2. Twisted (Dragon Set Swirling Paradox)
DRAGON > SAME FRONT SWIRL [DEX] > SAME IN/OUT [PDX][DEX] >
3. Frozen (Frigidosis Atomic)
FRIGIDOSIS > OP OUT [DEX] >
4. Arctic (Frigidosis Pixie)
FRIGIDOSIS > SAME IN [DEX] >
5. Canadian Frigidosis Terraging (Double Arctic)
FRIGIDOSIS > SAME IN [DEX] > SAME IN [DEX] >
6. Helical (Frigid Osis Set Sailing)
7. Gimpy (Stepping Op Knee Bump)
CLIP > OP IN> OP KNEE BUMP >
8. Pimpy (Pixie Same Knee Bump)
TOE > SAME IN > SAME KNEE BUMP >
NOTE: Pinching sets are not full dexes. Therefore they do not receive the dexterity add fairy/pixie only indicate the direction the bag is set.
9. Finchy (Pinching Fairy set)
PINCH > SAME OUT >
10. Pixie Pinching
PINCH > SAME IN >
11. Stepulous (Pendulum-Set Stepping)
XBD PENDULUM > OP IN > (SAME SIDE)
Anti-Symposium Sets:
1. Rooting/Rooted (Anti-Symposium)
Plant the setting foot (Op leg does not plant). Jump with the setting foot, setting the bag in the air.
2. Zoid (Rooted Crossbody Toe Set)
3. Hyper (Rooted Pixie)
Toe > (rooted) SAME IN [DEX][BOD] >
4. Railing (Hyper Atomic)
Toe > (rooted) SAME IN [DEX][BOD] > Op Out [DEX] >
5. Rooted Fairy
Toe > (rooted) SAME OUT [DEX][BOD] >
6. Frootie (Hyper Quantum)
Toe > (rooted) SAME IN [DEX][BOD] > OP IN [DEX] >
Last Updated 6/28/05.
1. Ducking
2. Diving
5. Spinning
6. Inspinning
Toe Sets:
1. Pixie
2. Fairy
13. Double Fairy
TOE>OP SWIRL>OP IN
Clipper Sets:
1. Swirling/Burly
3. Whirling
4. Blazing
Spinning Sets:
Unusual Sets:
PINCH > SAME OUT >
10. Pixie Pinching
PINCH > SAME IN >
5. Rooted Fairy
That's the best set name ever! Lets put Ales in charge of renaming all moves!9. Jolimont (Symposium Whirling Swirling)
missing
bs symposium frantic - beta frantic - pixie wanton - pixie symposium quamtum.
Also I think warp should be labeld as either flailing atomic or fronside symp omlette set. I don't think you can really call a set a symp eggbeating set - eggbeater isn't a set.
And Slaying isn't FrontSide Symposium Sailing, because it can't be... It is Beta Sailing = Pixie Flailing = Pixie Symposium Atomic
and Jobs is: Toe > Same In [DEX] > (no plant while) Op Out [BOD][DEX] >
And in Blurry next Dexterity does have to be paradox.
Good work man...
Good work man...
Pawel Ptaszynski
NAS
Be strong, LIVESTRONG
http://www.laf.org
http://www.wearyellow.com
NAS
http://www.laf.org
- bigdirtyfoot
- Sloppy
Okay thanks guys. I did this for everyone because I wanted something that was easier to understand; the order of the other one and the appearance just made it confusing to me. I'll update this when I get back from lunch. Also, is Jolimont the official name? You'll notice some just have technical names; what are their nontechnical names, if they have them. Alright, I'll update this in a bit.
- bigdirtyfoot
- Sloppy
Okay, I updated the list. I don't know who named Spinning Nuclear... anyways, I was wondering... there are some jobs missing for some sets, that I just wasn't sure about, or that I overlooked . Could anyone help with those? That would be great, thanks!
EDIT: Oh Golly, I forgot: thanks for all the praise too. I spent a few hours making this list turn out right, and I really appreciate it.
- bigdirtyfoot
- Sloppy
- King Monkey
haha yeh thats Bubba set!
im wondering if your description for Wontomic is a bit confusing? there needs to be some kind of punctuation to make it clearer, or just cut out one description... because 'Toe Shooting Symposium Quantum Atomic' set sounds like a 4 dex set!
Symposium Quantum Atomic is probably more accurate than toe shooting, because toe shooting isnt symposium, is it? but there may be some other way to describe it
nitpicking i know... but it does help with clarity and usefulness of the list
- bigdirtyfoot
- Sloppy
7. Pimpy (Pixie Same Knee Bump)
Does the knee bump have to be uptime? Or does it still count if downtime?
________
Suzuki X-90 specifications
________
- King Monkey
Pimping has the knee bump pretty much downtime; i think it would be waaay to hard to pixie set then knee bump it while still going up
