Fanzine
That sucks!
Good luck on recovery.
You probably already now this, but maybe you or somebody else can learn something:
The initial treatment for all sprains is RICE: Rest, Ice, Compression and Elevation.
Rest: Rest the injured ankle, avoiding any activity that causes further pain. Meanwhile, you can maintain conditioning with activities that won't stress the joint, such as riding a stationary bicycle, using a rowing machine or swimming with leg floats.
Ice: Apply ice as soon as possible. Ice decreases pain immediately by numbing the skin and reduces swelling by constricting blood vessels. Much of the pain from an injury is caused by swelling from torn blood vessels. Controlling the swelling helps you make a speedier recovery.
It's best to use crushed ice in a watertight bag covered with a thin cloth so it's not too cold against the skin. Apply it for 15 minutes directly over the area of swelling. Longer applications may cause a rebound dilation of the blood vessels and may actually increase swelling.
Apply the ice every four to eight hours as long as the swelling continues (even as long as a week). You can use chemical ice packs, but many experts warn that because they do not melt the same way as ice, they can overcool the ankle and cause a chemical freeze to the skin.
Compression: Compress the swollen area with an elastic bandage. Begin the wrap at the toes and continue it up about four inches above the ankle. If you begin the wrap above the toes, all the swelling is likely to accumulate in the toes.
Don't wrap it so tightly that it causes more pain or cuts off the circulation to your toes. While the elastic wrap can reduce further swelling, it usually doesn't provide enough support to prevent reinjury.
Elevation: Elevate the injured ankle as much as possible, particularly while applying ice; this allows gravity to drain some of the swelling. Place the ankle higher than the knee, the knee higher than the hip and the hip higher than the heart. Use books, a suitcase or a box under the mattress at night; this works better than a pillow.
This really has all the information you will need: http://www.sportsdoctor.com/articles/twisted.html
Keep on updating the blog even if you can't shred. It is good procrastiantion! :D
Tjuggles
Post by Tjuggles »
Hey Ken. I'm really sorry to hear about your ankle. I hope you heal swift and get back on your feet kicking...
This last JFC, I thought everyone should do something, sort of a way of saying thank you for all that you have done for the Japanese scene (you know, START one :wink: ), and as a way to show that we all missed you. Everyone helped to do THIS (below) and give a big 'ã
Post by C-Fan »
Wow, thanks a lot TJ! That really made my day, that was real sweet. The Japanese scene should be thankful my first name is so short. :P
Ankle is making surprisingly good progress. I am going about campus without crutches now, and the ankle is handling the weight OK. The biggest concern I have is all the slush on the ground. It makes my feet move in unanticipated/unwanted directions, and makes me really nervous about messing it up again.
Been trying not to think about footbag, cause I don't want to hurt myself air-shredding. I've been watching a RIDICULOUS amount of Simpsons (seasons 6 and 7) which has been a good distraction.
I miss you footbag. :(
dyalander
Post by dyalander »
Wow, the fast that it didn't swell up massively, and that you already have some weight on it a really good signs. It sounds like the severity hasn't been increased by the fact that you've done it before fairly recently which in turn suggests that whatever you did last time worked quite well. Continue to find ways to enjoy you're time off and I'm sure you'll get through it fine.
I wouldn't worry about it being an ongoing probelem either because I'm living proof that you can overcome serious, chronic, ankle problems at least once, well into your twenties. In fact a month or so ago I had a foot clash and landed on the outer edge of my supposedly weaker foot (in sprained ankle terms), but instead of rolling it, it snapped back down with enough force to almost make me roll the other ankle, luckily I'd fallen completely over by that time so all my weight was on my arse not my ankle. But it just goes to show you can not only recover, but if you continue to work you can really improve and strengthen your ankle, even if a tiny amount of pain remains after serious shred sessions.
Who wears short shorts?
Dylan Govender.
Post by C-Fan »
Thanks everybody for the advice and support. My ankle is feeling way better now; I can walk around normally and the ankle takes the weight fine. I only feel anything weird in it when I do certain positions, and even then its not really painful. I can “air clipperâ€
Post by C-Fan »
Got in my first post-injury session on Friday, and it went well. I watched lots of Luis Monhollon footage before the session to inspire me to play lightly. I played at juggling club, so I'd be able to take juggling breaks and not end up playing too hard. For the most part it worked.
My ankle definitely isn't 100% yet, but I feel confident I'll make a full recovery. I twisted my ankle last semester, and it took about a month of stretching, playing, and tough sessions to get it back to normal. I remember my first few sessions back were pretty painful, but on Friday I was fine. I just wasn't able to flex my ankle as much as I normally do. I feel pretty confident I'll make a full recovery, but even if I don't, at least I'll be able to still play footbag.
Minor session highlights:
*zooming dlo
*whirl-dyno repeat
*suuuuuuuuuuuuuper clean PSDLO. Textbook.
The biggest highlight though was simply being able to play, and playing without pain.
I've got an IM basketball game in 45 minutes, and I think I'll play a chunk. So far we've played 3 games and I've only played like 5 minutes total, since I'm the coach/team manager and I want to give everybody minutes. But today we already secured a berth in the playoffs, so I'm gonna put myself in the game and have some fun. I'll be careful.
Post by C-Fan »
Played on Monday and again last night. Both times with Pascal, both times pain free. Monday was a real good session. My right ankle felt more flexible than before, but it also kinda lacked strength. I avoided certain combos and moves because I lacked confidence in that ankle taking the weight, and a few times step sets on that side kinda felt tweaky.
Because my right ankle couldn't take weight, I ended up working a lot of flipsided stuff like PS whirl. Flip PS whirl is definitely progressing nicely in part due to the injury.
Highlights:
*ps whirl x3
*tomahawk x2 real clean.
*flipside mullet! 8O That was a surprise. So stoked about it, I decided to risk strongside mullet so I could get BSOS, and I got it!
*flipside mullet a few more times, some better than others.
*flip ps whirl-ripwalk
*zooming torque midstring
On Wednesday I got Taco (rats) Bell with Pascal before playing, so I felt pretty heavy and slow throughout. No real highlights to speak of, but I was able to link shuffle together (smear-toe blur repeat, rubberman-esque stuff) a lot more easily.
I definitely still need to be careful, because at this stage of my recovery its tempting to play hard, but that's very risky. I'm gonna try and play relatively lightly for the next few weeks, and then start going back to my old level hopefully.
This semester has been real challenging for sure, but I'm doing OK about staying positive. My fast recovery on the ankle is something I'm definitely grateful for... the other day I saw video of an NBA player I like sustain one of the most gruesome injuries I've ever seen, and that made me feel truly grateful that my legs are still going strong after 10 years of footbag. If you have a strong stomach, check it out:
http://www.youtube.com/watch?v=RDrA0bWPlhU
Post by C-Fan »
Got in a small session last night with Luis and Nick which was fun. I spent a lot of time teaching a couple 8 year olds how to kick, so i didn't have much time to shred hard myself. Ankle felt pretty good. Just gotta make a point to go slow for a few more weeks and bring it along at its own pace.
I'm gonna go play in 10 minutes, but I just realized I forgot to post my best highlight from last session:
I started a run with enterrage, then had flurry ending on the other toe, tomahawk to pdx torque, bsosed tomahawk, and I think I had a bl. whirl in that run too.
Pyroman924
Post by Pyroman924 »
Props on everything Ken!
That's a sweet run you had. :D
And Props x2 for Mullet BSOS!
Hope everything is going well. :)
Alan Underhill
http://www.myspace.com/pyroman924
"The more you drop, the better you get." -Ben Rinowski
Post by HG »
So here's how my day went yesterday
Play some Capcom vs Marvel 2
Play some basketball
Play some footbag
Do some homework
I was Ken Somolinos yesterday. :wink:
Post by C-Fan »
:lol: Cool. That sounds like a really ideal day. I haven't had a chance to play MvC2 since I got back from Japan in the summer... I definitely miss it. My IM basketball team made it to the playoffs, and we have our first game Tuesday night which is exciting. So life is mostly schoolwork and footbag, and definitely a lot more of the former.
This weekend was pretty good: I got to play footbag on Friday AND Saturday. Saturday was particularly good, as I got to play foursquare for the first time in ages.
The ankle still isn't 100%, but you can't rush these things. It is a bit frustrating though, because I know I'm dropping a lot of tricks and links due to it. I feel like I can't complain about not being 100%, because I should feel lucky that I'm able to play at all. Really, the ankle has made remarkable progress. Just got to keep playing, stretching, and try to use the injury as an opportunity to work on other parts of my game.
Not much in the way of real highlights. Matador bsos was a nice surprise. Blurry whirl-food was also encouraging. Dyno-far swirl felt styly. But really, highlights when you are injured are only really meaningful as a barometer of your recovery. I haven't really hit much since the injury that I would consider even close to what I was doing before, and that goes for consistency too.
My spring break plans are still open, and I need to figure them out soon.
slapdash21
Futureless
Post by slapdash21 »
duuuuh ken come to boston! :P
Pete Bowler
B$C
keeps it offah da ground.
617 FOR LIFE
Post by Senor Grommet »
Run with the big boys:
http://www.isc.ro
Skrabblist=Jeremy
sweetninja=Fletch
Post by C-Fan »
Gah, I still don't have my spring break plans finalized. Life has been crazy stressful lately, what with midterms, intern applications, -20 windchill weather, and assorted other headaches. I really need to get out of here.
In good news, my ankle is feeling great. Last night I got in a good session with Pascal and Luis, which I really needed mentally. Before footbag, I got in a real intense game of air hockey with Pascal, which I found surprisingly exciting.
Shred itself was very good. I warmed up slowly, didn't force anything, and just let the highlights come to me.
Highlights:
*whirling swirl bsos
*ducking pdlo
*ps whirl-ps whirl-mobius off my foot twice.
*jani-thin blurriest. I was just happy the jani was good enough to step out of. If I wasn't so surprised, I would have cleaned it.
*fog- {leg-blur-atom} repeat-smog off the foot.
*flip fog- {leg-blur-atom} repeat- atom-smear-atom-dimwalk-some other tricks.
*ps whirl bsos, with predator, flurry, pigbeater, and fog in the same run.
There were times like I almost felt like my old self, but I don't want to get too excited. I know there will be up and down sessions until I fully heal, but it still felt great to have my body doing more of the things I wanted it to.
Thank you footbag for keeping me sane.
Post by C-Fan »
Dear Blog,
Sorry for the recent neglect. I’d say about half of that was due to a recent crunch in schoolwork and internship deadlines, and the other half was due to there not being that much great footbag stuff to report.
So what’s new? My IM basketball team made the playoffs and we won our first game, but we lost our second which means we got knocked out of the tourney. It was a tough loss on a lot of levels, but for the purposes of this blog, the worst part was bruising my hipbone. I’m pretty sure it’s not a muscle strain so much as an actual bone bruise, because the skin never changed color and the pain feels similar to when I bruised my rib over the summer. Not much I can do about it, except wait til it heals.
The day after bruising my hip I performed a footbag routine for a cancer fundraiser my program was holding. I did my “Under Pressureâ€
Pyroman924
Bad luck on the hip man. >_< You're just an injury magnet! Heh, hope you get well soon though.
Props on performing though, even if you did drop a lot, you still went out and did it and that's what counts in the end. :D
P.S.-
It's Always Sunny In Philadelphia is such a great show. :wink:
Alan Underhill
Post by C-Fan »
F* it all, I`m going to Miami for a week.
I get into town Saturday night, leave on Thursday morning. I`ll crash with Klokow or Strassman for a bit, and when they get sick of me I`ll sleep in the campus library or on the beach. But the tickets are bought, and I`m going, so it`s official.
Post by Moxie »
Boooo!
Have fun. :-D
Post by C-Fan »
It’s like Spring Break is here early. After a crush of subzero (with windchill we hit -20 a few days in a row) weather last week, the snow decided to melt and the sun shine. It was easily 50 degrees outside yesterday, if not well into the 60s. Grass peeked out from under snow, girls were out jogging, and I did my part by getting in my first outdoor session of the semester. I called everybody, but Pascal was out of town and everybody else had prelims hanging over their heads. But there was no way I was gonna waste this weather. Grabbed the units, shorts and a bag, and hit the outdoor basketball courts by my place.
Before I could even warm up however, a friend from my IM basketball team randomly walked by and said hey. I showed him a little footbag and he gamely tried for a few kicks. Soon enough though, he suggested a game of 1-on-1, so I said “sure why not.â€
Post by C-Fan »
Gave blood today, which normally wouldn't be blog-worthy except for one thing that happened which gives me hopes for a fast recovery. After giving blood they always give you cookies and juice to put sugar back in your bloodstream. The cookies were on a plate, so I couldn't see what box they came from. I really enjoyed a particular kind of cookie, so when it ran out, I asked if they could put out some more from the box. They take out the box, and guess what brand it was?
Little Debbie! 8O If there's any cookie which should help me get back into footbag form, that's it, so hopefully with Deb Deb's help I'll be back in shred shape by Sunday, when I get in a session with Klokow and Strassman.
