Precautions with lead
try google searching it, i did and this is what i got
Physical Symptoms
Stomachaches, cramping, constipation, or diarrhea ( will cause ur face to look like mitko's avatar)
Nausea, vomiting
Persistent, unexplained fatigue
Headache
Muscle weakness
Higher rates of tooth decay
Behavioral symptoms
Irritability or aggressiveness
Hyperactivity, being easily distracted, impulsiveness
Learning problems
Lack of interest in play
Loss of appetite
Irritability
Unexplained changes in mood or personality
Changes in sleep patterns
Inability to concentrate
Memory loss
Neurological symptoms
Poor coordination
Weakness in hands and feet
Headaches
Seizures
Paralysis
Coma
Physical Symptoms
Nausea, vomiting
Headache
Muscle weakness
Behavioral symptoms
Learning problems
Loss of appetite
Irritability
Memory loss
Poor coordination
Headaches
Seizures
Paralysis
Coma
- sanuke okumatzu
has anyone been exposed to lead filled footbag for a long time and has no ill affects that you know of?
Basically im just wondering if lead filled footbags would have an affect on someone's health over a long period of time...a few years or so. I get cramps in my hand and stupidly think its the lead thats fucking up my hand and shit. my concious will never let me be at peace
- Bringerofpie
Cramping isn't in the list of symptoms you posted.
Joe Snyder
Joe Snyder
I think you're describing another problemBenzilla wrote:has anyone been exposed to lead filled footbag for a long time and has no ill affects that you know of?
Use your good judgement. If you're using lead in a safe manner, which wouldn't be a bad idea to read up on-you'll be ok.
My chemistry teacher(s) say so too!
yeah, i read somewhere that they used to use lead printing keys on really old printing presses and people where getting arthritis from the lead so they had a tool to pick up each letter and then i guess stopped using lead altogether.
But you're right. the way you use it can be the biggest variable. I rarely ever touch it with lead contacting my skin. The only way im ever touching it is with a layer of facil between me and the lead, basically only when its in a bag.
I handle lead everyday at work, get the dust all over my hands. I have not had any problems at all. Only certain compounds of lead can be quickly absorbed through the skin, such as lead acetate. Formed lead like shot is not easily absorbed through the skin. Kicking a bag around will create some dust, however not enough to cause any problem UNLESS you have a cut on a part of your body for it to enter or, you have it on your hands and put them in your mouth, nose, or rub eyes. Symptoms of lead poisoning by skin absorbtion resemble a rash and will also be painful in and around the affected area. Usually symptoms of poisoning via absorbtion are a result of chronic high level exposure (hands visibly coated for quite some time) and not acute exposure (little on hands then washed off.)
There are a multitude of MSDS (material safety data sheet) for the many different forms of lead, I am going by one I read reagarding lead sheeting which is more unstable then lead shot.
In all, Just wash your hands if you have a lead bag and you should be in much better shape than me.
Here is a MSDS of lead shot #8 This is the legal standard for the precaution of the type of lead in most footbags!!!! For comparison on the hazard rating, "health 2" is as bad as drinking windex, 3 would be huffing gas, 4 would be cooking meth and 5 would be about as bad as drinking a cup of gas.
Material Safety Data Sheet
Chemtrec 800-424-9300
24 Hour Emergency Assistance
Section 1 Identification
Product Number: C1964 Health: 2
Flammability 0
Reactivity 0
Hazard Rating:
Least Slight Moderate High Extreme
0 1 2 3 4
NA = Not Applicable NE = Not Established
Product Name: Lead Shot #8
Trade/Chemical Synonyms
Formula: Pb
RTECS: OF7525000
C.A.S CAS# 7439-92-1
Section 2 Component Mixture
Sara 313 Component CAS Number % Dim Exposure Limits:
Lead Shot #8 CAS# 7439-92-1 100% w/w OSHA PEL 0.05 mg/mÆ’
Section 3 Hazard Identification (Also see section 11)
Harmful if swallowed. May cause irritation. Avoid breathing vapors, or dusts. Use with adequate ventilation. Avoid contact with eyes, skin, and clothes. Wash thoroughly after handling. Keep container closed.
Section 4 First Aid Measures
FIRST AID: SKIN: Remove contaminated clothing. Wash exposed area with soap and water. If symptoms persist, seek medical attention
EYES: Wash eyes with plenty of water for at least 15 minutes, lifting lids occasionally. Seek Medical Aid. INHALATION: Remove to fresh air. If not breathing, give artificial respiration. If breathing is difficult, give oxygen
INGESTION: If swallowed, induce vomiting immediately after giving two glasses of water. Never give anything by mouth to an unconscious person.
Section 5 Fire Fighting Measures
Fire Extinguisher Type: Any means suitable for extinguishing surrounding fire
Fire/Explosion Hazards: Negligible fire hazard when exposed to heat or flame.can produce toxic lead fumes and lead oxide fumes at elevated temp.
Fire Fighting Procedure: Wear self-contained breathing apparatus and protective clothing to prevent contact with skin and clothing.
Section 6 Accidental Release Measures
Wear Protective equipment. Sweep up, place in a bag and package unreclamied matl for disposal.
Section 7 Handling and Storage
Store in a cool, dry, well-ventilated place away from incompatible materials. Wash thoroughly after handling.
Section 8 Exposure Controls & Personal Protection
Respiratory Protection:NIOSH/MSHA-approved respirator
Ventilation: Mechanical: Hand Protection: NIOSH Approved Gloves
Local Exhaust: Eye Protection: Splash Goggles
Other Protective Equipment: Wear appropriate clothing to prevent skin exposure
Section 9 Physical and Chemical Properties
Melting Point: 327.5°c Specific Gravity 11.34
Boiling Point: 1740° Percent Volatile by Volume: info not available
Vapor Pressure: mmhg/70f (see supp) Evaporation Rate: info not available
Vapor Density: Information not available Evaporation Standard: Water =1
Solubility in Water: insoluble Auto ignition Temperature: info not available
Appearance and Odor: blue gray granules,odorless Lower Flamm. Limit in Air: info not available
Flash Point: info not available Upper Flamm. Limit in Air: info not available
Section 10 Stability and Reactivity Information
Stability: Stable Conditions to Avoid: stable under ord conditions of storage and use.
Materials to Avoid:
ammonium nitrate, chlorine trifluoride, hydrogen peroxide
Hazardous Decomposition Products:
does not decompose,but toxic lead fumes may occur
Hazardous Polymerization:Will Not Occur
Condition to Avoid:None known
Section 11 Additional Information
lead is acumulative POISON!! And exposure in the smallest amts can raise bodys content to toxic levels. Symptoms of chronic exposure are like those of ingestion poisoning restlessness and irritabilty may also be noted.eyes:wash with plenty of water skin:wash exposed area with soap and water.ingest: induce vomiting bt giving two glasses of water and sticking finger down throat providing persons is conscious.in all cases seek medical atten.conditions aggravated/target organs. Persons with pre-existing eye,skin or respiratory conditions may be more suscetible.
DOT Classification: Not Regulated
DOT regulations may change from time to time. Please consult the most recent version of the relevant regulations.
Revision No:0 Date Entered: 9/1/2006 Approved by: WPF
Flammability 0
Reactivity 0
Hazard Rating:
0 1 2 3 4
Formula: Pb
RTECS: OF7525000
Materials to Avoid:
