What is "variety?"
Right, but when you're considering variety within the larger category of the technical score or when considering the "variety" thing in circles, all other things being equal,do you think variety of sets and variety of mid/downtime components are of equal value?Jeremy wrote:There are no competitions where there are a variety and a technical score. In routines you have "technical" and "artistic" - of which variety would fit in to "technical."
Also in Circle where there is the "variety" theme I wouldn't count proficiency across surfaces or sidedness as part of that score. I think these are "technical" issues better kept out of "variety" where this latter term is being used as a judging theme for circle. I think if you're going to do the themed circle rounds then make the themes as simple as possible.
Similarly, I agree that order of tricks (or the variety of links) should not be part of the "variety" score. Personally, while I can see Jeremy's point when he notes an exception, I wouldn't make such exceptions, I would consider "variety" purely in terms of sets and components, not the way the previous move affects the nature of a set - I would classify that as a matter for "links" or "difficulty". Even though this makes thing like spinning out of osis the same as spinning out of a butterfly as far as "variety" is concerned, I think its better to keep the judging simple even if it means that the criteria is a little more artifical.
Who wears short shorts?
Dylan Govender.
Dylan Govender.
- james_dean
- space cowboy
