Even though I knew exactly what the problem was-- my patella tendon at the kneecap hurt from repetitive impact-- my doctor spent a long time searching for other causes. He even measured the height of each side of my hip to see if it was off. Oh well, after an hour of this he finally conceded that it probably was... patella pain from repetitive impact. He also mentioned that it could be sinding-larsen-johansson syndrome, but that generally affects adolescents between 10 and 14, so that's sorta far-fetched. Either way, I got the conclusion I wanted: after I asked, he agreed to write a referral to physical therapy. I start tomorrow at 9 am, and hopefully they'll be able to offer some exercises or weight-lifts I can do that will help. Can't wait!
I also threw in a set of Dr. Scholl's into my g-units for two reasons: to reduce the space between the toe surface and my foot so that there wouldn't be that angling problem and also to add even more cushion just for safety. The insert did both. Man, playing felt great-- nearly no discomfort. The inserts also made the clippers not quite so ridicul-easy, which is also cool with me.
I played about 1.5 hours and worked a lot on spinning and fairys, but did a few reverse swirls (not too hard), some consecutive butterflys, and a wee bit of atomics. Learned that my flip spinning is better when the set is from farther out; a farther set gives more control, more room for error, and more power. I also improved my fairy technique somewhat, and was able to foot fear both sides pretty consistently. I hit the usual cache of fear bs, fairy ss mirage bs, atomsmasher, and also managed butterfly > spinning osis > butterfly bs, which felt pretty classy. Spinning clipper > blur bs was in there too.
Though my right knee didn't hurt at all during the session, it does feel a bit tender now. I think it'll feel fine by tomorrow though.
