I think sailing mirage might be one of the easiest triple dexes.. although i can't hit n e triple so maybe not
My first double dex
My first double dex was pixie legover.
First triple was smog barefoot or sailing ss mirage (possibly the).
The difference between Pixie DOD and Pixie Paradon is that Pixie DOD is all dexed with the same leg so its a Pixie ss Paradon and with Pixie paradon you set with one leg and do the other 2 dexes with your other leg. I think thats it.
Robin Davies
You are your Footbag
- buddystarr
- Hack Fiend
- tuomoruutufan
I've been doing pixie legovers longer than I've been doing any other 3 add move(aside from butterfly kick.) It is most certainly the easiest doulbe dex move, because you can start the second dex almost before you end the first one.
Whats the hardest double dex? I think it would be rev swirling op rev swirl
are you talking about the hardest that has been hit or the hardest that could possibly be hit?
Spinning pdx barroque is the hardest I can think of that's been hit although I've never seen it hit cleanly on video. Maybe stepping inspinning pdx whirl is the hardest I've seen on video. It's very hard to recall all the hard 2 dex moves that have been hit though...
