easiest 6 add?
- SnowBlindSloth
- max
- Australofrenchbrityorkus
haha! Good call Cod! I was thinking of fairy symp. swirling op pickup for some reason...Cod wrote:The 1st is Fairy, the 2nd is Swirl and the 3rd dex is... Osis?max wrote:Absolutely. It also qualifies for easiest triple dex in my book!janis wrote:everyone should try fairy symp swirling osis, it's really easy.
Maxime Boucoiran
French ConneXion
BFC
French ConneXion
BFC
You guys so have to clarify sameside, or just say surfing (symp phasing) same. I read it and thought you were talking about fairy symp swirling osis, and couldn't figure out what the heck you were on...
I thought you meant:
toe > same out [DEX] >> (no plant while) same back swirl [BOD][DEX] > (back) spin [BOD] > op clip [XBD][DEL]
Like a fairy symp reverse twirl.
For me, mullet is definitely the easiest, and I think the easiest to fluke without having to actually know any components... One dex.
Surely you can tell if it's same side or op side just by the fact that one is way easier than the other, and this is a topic about the easiest 6 add.
There are a few 6 add moves I've hit first attempt and never try that are definitely up there. Sailing ss da da curve. Symp tapping symp reverse whirl. I think I've probably mentioned those moves earlier in this topic already.
Symp atomic da da curve actually sounds more difficult than many of the moves here. If you're doing it ss then the wrong leg is on the ground at the start of the da da curve (meaning you have to do it symple or change feet), and if you're doing it op side it gets an x dex making it 7 adds. Although that said, all moves that end in dada curve are easier than doing the same move ending with a drifter or a dlo, so it's still easy relative to similar tricks.
- Blue_turnip
oh yeah. Ollie hasn't played much in the last 3 years and he hit it easily.Blue_turnip wrote:Yeah and in case there was still even a bit of doubt left, today eliminated that in my books.janis wrote:yep today pretty much proves it, symp phasing osis is the easiest 6add. Jamie hit it for the first time after a few attempts then I hit it when the bag was passed to me.
- mannampepo
- sonofgenkai18
- Shredalicious
- mannampepo
