Early Tricks
Early Tricks
I'm just starting out... I can hit a legover, around the world on both sides, and I've hit mirage a few times. What are some other basic tricks I can work on ?
Marc Reinecker
These moves are fundamental elements of more advanced moves. You will want these dialed before you progress:
Mirage and Illusion
Legover and Pickup
Clipper
These are probably less important later on but easier to master and add variety to your tiltless game:
Around the World In and Around the World Out
Pixie and Fairy
Mirage and Illusion
Legover and Pickup
Clipper
Pixie and Fairy
Guest
To train the clipper stal do inside stals and then wrap them around ur support leg to the clipper posistion, hold it there, then unwrap. try doing consecutive clippers and alternating. however, when performing these drills there is a distinct "magic" hop. you sort of fall into your clippers with a light jump, landing on your support leg while your catch leg lifts and stals the bag. Too many times have I seen noobs do clippers with unbalanced support legs/odd hops that dont make them as smooth as they should be.
- Outsider
- Ayatollah of Rock n' Rollah
Flying Clippers an d Dragonflys.
Start skooling flyers early, if only a little at a time, so that they don't feel really awkward later. Don't limit your game to dexing stalls.
The Ministry of Silly Walks
NYFA
BAP
NYFA
BAP
- crazydwarf
