Team Fortress 2
rjadamson
Post by rjadamson »
Most points:195 (as Heavy)
Most kills:148 (as Heavy)
Most kills by sentry:54 (as Engineer)
Most assists:60 (as Medic)
Most captures:20 (as Scout)
Most defenses:13 (as Heavy)
Most damage:31,144 (as Heavy)
Most destruction:23 (as Spy)
Most dominations:15 (as Demoman)
Most revenges:3 (as Heavy)
Most ÜberCharges:21 (as Medic)
Longest life:105:28 (as Engineer)
Most backstabs:9 (as Spy)
Most buildings built:287 (as Engineer)
Most headshots:14 (as Sniper)
Most health healed:39,395 (as Medic)
Most health leeched:147 (as Spy)
Most teleports:116 (as Engineer)
Most of these numbers come from playing ctf_2fort, so they might not count for much. If I just want to kill some time/energy after work I will play on that map because most people who play there don't care about capturing the flag. It's a lax sandbox atmosphere that leaves me to farm kills or practice things. Finally, I generally don't have to deal with the frustration of topping the scoreboard by a large margin and losing because the teams are completely stacked.
Post by C-Fan »
We really need to play together again. I have pool playoffs tonight at 7 mountain time, but I'm free for the couple hours before that. Want to play?
akalazou
Post by akalazou »
C-Fan wrote:You should make a point to get one of the rocket launchers that only has 3 rockets in the clip. The default rocket launcher has 4, but ones like the Black Box only have three.
The reason why should be obvious.
I'll add you tonight.
i personnaly use the black box caus i dont really play as if there was a medic in our team, i prefer to deal damage and get HP ... + im very accurate now so my HP goes up kinda fast, even if im an arena player.
When i dont arena, i play on cp maps and i often get near to 0 ammo and since im topping the score often and i think i can make my team win because there are a lot of noobs, i stay with my black box :D
Julien Cote
Post by C-Fan »
Kevin's catchphrase is "boom boom boom!" Hence my suggestion. :)
akalazou
Post by akalazou »
btw, MathieuGM started to play too. look into my friend list and add Mat
Julien Cote
akalazou
Post by akalazou »
C-Fan wrote:No, what's that?
i forgot to say about mge_maps
i dont know if there is only one map but the map i know is separated in "rings", each ring is a part of a well knonw map, like the last point of cp_granary. so you train in 1on1
Julien Cote
Post by C-Fan »
Sporatical_Distractions wrote:Just downloaded tf2. Add me. username: missoulafootbagalliance
I couldn't seem to find you. Can you add me? Username is my last name.
While I'm here, what do people think are the cheapest items in the game? For me it's probably:
:arrow: Phlogostinator. Lack of an airblast doesn't come close to making up for the ability to essentially completely reheal yourself AND get kritz at the same time. Broken as hell.
:arrow: Eternal Reward. No sound on death, and immediate disguise? Anybody who can use the Cloak and Dagger with any ability at all can and will abuse the shit out of this.
Others?
rjadamson
Post by rjadamson »
They break Sandvich. Is bad.
Updated the Heavy's sandvich so it will only resupply ammo if the owner picks it up after dropping it. This means the only way to gain health from the sandvich is by eating it.
I would say the Phlogostinator was a good pick for the list of most unbalanced items. However, even it doesn't hold a candle to the champion of recent stupid additions to the TF2 arsenal, the Pomson 6000. Its lasers go through players, it removes 20% of the cloak from Spies, and worst of all it removes 10% of a Medic's charge on hit. That last part in particular makes for extremely stagnant matches because now Medics either have to hit their charge early (essentially halving the effectiveness of any given push) or risk suddenly dropping to 90% charge when their teammate is running into a heavily fortified area.
Post by C-Fan »
Good call on the Pomson. I have used it some (mostly because it doesn't use metal/ammo), but didn't realize it affected medics and spies the way you described. I also didn't realize the Sandvich was changed and downgraded like that. That sucks. Is that the same case with the Buffalo Steak?
We should play again. I'm sure I can find some time this weekend...you down?
akalazou
Post by akalazou »
as an arena player, i hate good spies with the death ringer caus you cant kill them at all caus they always know where the metal is and they are always the last player alive.
the pomson and the phlogos... are pretty bad too
Julien Cote
Post by C-Fan »
C-Fan wrote:Good call on the Pomson. I have used it some (mostly because it doesn't use metal/ammo), but didn't realize it affected medics and spies the way you described.
I feel like I have to admit this in public: after learning about this, I've totally started using the Pomson more, and specifically used it to target any medics I see anywhere. :oops: As a frequent engie who often can't rely on his team to protect his nests, I'll take almost anything to make sure my nest survives.
Post by C-Fan »
I've just started acquiring and using strange weapons. What stranges do you have, and what ranks are they at?
I currently have 4 strange weapons. I'll check and post their counts tonight, but I'm pretty sure about their ranks:
:arrow: "Gore-spattered" medigun
:arrow: "Uncharitable" knife
:arrow: "Scarcely lethal" Bonesaw
:arrow: "Unremarkable" Eyelander
So far the knife has been the easiest to level up. The medigun counts ubers, which is weird to me since I think assists would make more sense to track.
rjadamson
Post by rjadamson »
C-Fan wrote:I feel like I have to admit this in public: after learning about this, I've totally started using the Pomson more, and specifically used it to target any medics I see anywhere. :oops: As a frequent engie who often can't rely on his team to protect his nests, I'll take almost anything to make sure my nest survives.
I still use the Frontier Justice, so I pretty much treat my buildings as disposable. Sure, kill my stuff, give me a dozen revenge crits to unload!
C-Fan wrote:I've just started acquiring and using strange weapons. What stranges do you have, and what ranks are they at?
  • "Hale's Own" Minigun: 40,236 kills
  • "Wicked Nasty" Gloves of Running Urgently: 607 kills
Post by C-Fan »
:arrow: "Gore-spattered" medigun -363 ubers
:arrow: "Notably Dangerous" knife-141 kills
:arrow: "Scarcely lethal" Bonesaw -35 kills
:arrow: "Scarcely lethal" Eyelander- 26 heads
AlekseyV
Post by AlekseyV »
r3action0 - add me :P
anybody play dota 2?
worldbound
Post by worldbound »
Just played for a while sitting next to MathieuGM at his house. Good times!
Mike Green
footblog
kicking since Mar 27, 2011
Post by C-Fan »
Lately I've been focusing on leveling up my strange knife. I'd forgotten how fun it is to play spy.
C-Fan wrote::arrow: "Gore-spattered" medigun -363 ubers
:arrow: "Gore-spattered" medigun -429 ubers
:arrow: "Gore-spattered" knife-363kills
:arrow: "Mildly menacing" Bonesaw -52 kills
:arrow: "Scarcely lethal" Eyelander- 28 heads
Post by C-Fan »
C-Fan wrote: :arrow: "Gore-spattered" medigun -429 ubers
:arrow: "Wicked Nasty" medigun -503 ubers
:arrow: "Wicked Nasty" knife-576 kills
:arrow: "Somewhat threatening" Bonesaw -71 kills
:arrow: "Scarcely lethal" Eyelander- 29 heads
akalazou
Post by akalazou »
here are mine:
:arrow: face-Melting Scattergun - Kills: 1352
:arrow: Sufficiently Lethal Pistol - Kills: 192
:arrow: Notably Dangerous Bat - Kills: 143 (i probably have a lot more bonks than that but they don't count them :( )
:arrow: Wicked Nasty Sniper Rifle - Kills: 628
:arrow: Spectacularly Lethal Jar Based Karate - Sodden Victims: 281
:arrow: Somewhat Threatening Kukri - Kills: 89
:arrow: Epic Rocket Launcher - Kills: 5835 (in fact, thats the black box)
:arrow: Somewhat Threatening Shotgun - Kills: 81
:arrow: Truly Feared Pickaxe - Kills: 246
:arrow: Unremarkable Syringe Gun - Kills: 19
:arrow: Mildly Menacing Medi Gun - Ubers: 52
:arrow: Somewhat Threatening Bonesaw - Kills: 75
:arrow: Unremarkable Bonesaw - Kills: 17
:arrow: Strange Boxing Gloves - Kills: 3
:arrow: Somewhat Threatening Wrench - Sentry Kills: 80
i have a lot more stranges at 0 kill that i dont use
i mainly play 2 classes,
soldier with strange black box, gunboats and strange equalazer
scout with strange scattergun, strange pistol, strange sandman
Julien Cote
akalazou
Post by akalazou »
i forgot to say that i started to play on cp_badlands. It very fun as a soldier, there are many cool jumps to make.
Plus, i had my first try at double airshot and i succeded !!! there was a medic on a soldier, i threw a rocket at the soldier feet, he went up. Then like i always do, i shot another one to make the kill in the air but he didnt die because he had the medic. SO i had the chance to shot another one and i made the kill. I was like "OMG!!! I DID IT !!!" that was awesome !!!! :D
Julien Cote
