What is modified's opinion on the grippyness of shoes. I tried out tom mosher's climacools last night and the clipper area did have more grip. He also mentioned that Vasek was playing at worlds in some reverse moded lavers.
Do the mesh rod lavers provide enough grip or is reverse modding the best way to go? Thoughts? What about putting down some 1200 grit sandpaper on the inside of the shoe :p
thanks
Shoes and grip ...
Shoes and grip ...
Jon's FootBlog
MSN: [email protected]
brian relly
- fan-tas-tic
Vasek also won 3 world championships with regularly modded lavers, so I don't think it makes that much of a difference.
esteban barnez
myspace.com/rawcakes
david wrote:I was just sitting here surfing and my mom looks over my shoulder. I had to jab down the down key real quick so she wouldn't see that topic title and question me about what kind of site I was going on.
ya thats what it means
Jon's FootBlog
brian relly
- fan-tas-tic
Stop acting like you know everything. There is more than one way to do many things, it all comes down to preference.wally wally wally wrote:Then reverse moding is definately the way to go, no question about it.
The canvas is grippier, yeah, it's also thick, and it's a cloth, thus making it prone to wear thin and tear. The mesh, despite its slippery quality, is way way way thinner, and also way way way stronger, because it's nylon. It's not going to wear thin in places (unless you, like, sand it or something) or tear, unless you actually cut it with something. The mesh also doesn't look tacky as shit, because you can't see the modification.
It just comes down to what's more important to you, there's no right answer, and there's no "no question about it."
edit: But if you have good form, the "slipperiness" of the mesh shouldn't matter at all.
esteban barnez
Chema
- Location: Footn'Bag (Boise), Idaho, USA, Earth, Frappr Map
I find that grip helps give you the ability to choose the direction in which the footbag goes after the set. When I tried spins without grip I would often not set the bag high enough because it would slip off as I was setting it and beginning the spin, with grip however the bag will stay until I want it to leave.
Chema CB
