Double Torque (Barroque)
Uranos
Post by Uranos »
SET >> OP IN [DEX] > SAME IN [DEX] > BACKSPIN [BOD] > OP CLIP [XBD][DEL]
I found there was no tips for this tip and i was wondering if somebody had some useful tips on this.
Thanks!
Alex Urano
this is the move that made me want to start wanting to learn footbag. any tips would be great
Blackend
Post by Blackend »
Here's a tip for you Kevin:
GET BACK TO WORK!
Sorry to put this in here, but I needed to yell at Kevin. And, any tips on barroque would be freakin' sweet because Kevin's been bitching about this move forever. Well, not really bitching, just more of a once in a blue moon whine. ;)
Sam Mayer
"Son, a woman is like a beer. They smell good, they look good, you'd step over your own mother just to get one!" - Homer Simpson
the way I hit barroque is basically like a blazing ss torque so the first dex starts as early as is possible and is whirling style so the dex finishes with the bag still outside of your knee - then you just continue the leg around into a torque. You can start jumping for the torque while you're doing the first dex however.
max
Australofrenchbrityorkus
Post by max »
My tip or barroque is to school downtime clip set barrage and clip set torque a lot. Once those two are down for the barroque try this:
- set rather low and start the first dex as soon as possible
- once you set you should turn your shoulders exactly like you were doing a torque.
I see this trick more as a BIG torque than a barrage bail to osis.
Maxime Boucoiran
French ConneXion
BFC
