alternating: toe stalls
Nitrox
Post by Nitrox »
(as requested by Matt Cross)
I'm having trouble getting the rhythm down with toe stalls. I can go back and forth between toe stalls for dozens at a time, but there's a slight pause in between. I see the way my friend does it...he sorta bounces off his setting foot right after the set, but I can't see to get it down. Any tips for that?
--Josh Ohana--
My Blog
Challenge Me
Josh,
practice bouncing from one foot to the other with tiny little jumps, just like you see your friend doing.
Then practice doing a tiny toe set, and switch which foot is planted so the other foot is in the air right under the bag, ready for the catch. it will take a little practice, but conceptually, it's really straightforward.
m
Colin
Post by Colin »
Try alternating toe stalls without letting your heels hit the ground. You'll get bouncy in no time.
Colin Kennedy
[email protected]
crazylegs32
Post by crazylegs32 »
Stay on your toes!! Dont let your weight get onto your heels...
Guest_2
Post by Guest_2 »
It's like a goofy little skip
Bander87
Post by Bander87 »
When you are about to stall it, make sure that your support leg raises and falls a little bit on its toes.
