i couldn't find a topic on this, so lemme know if there was a previous one. Thanks
How far does a yard go?
Im looking into buying some facile in a couple weeks. I was wondering how many footbags could you potentially make out of a yard of facile?
Josiah Digges
Embassy Footbag Crew
Kyle Hewitt
- something more funny
- Will Digges
My first footbag wasn't made from facile. I don't feel like you need to bother with facile until you've got a handle on the stitching. Facile's a tricky fabric because it leaves almost no room for error since it's not a woven fabric and you can't just backtrack or replace your needle placement.
My first footbag was made out of a thick crushed panne-like material. Check for some faux suede at your local fabric store. It'll be sufficient to practice on.
Pengpeng Du
- Will Digges
Yea i wasn't planning on getting a whole yard of one color. i just wanted to know how many you could make out of just one yard to conceptualize how much facile would cost when i was ready to start stitching it. I've got a fabric store a couple blocks down the street from me. Ill hit it up after new years after the stitching tutorial
thanks peng!
Josiah Digges
- shredzilla
My first bag was a 32 facile. Just make sure you use the right templates. There's no problem with starting with facile, or starting with a 32 pattern, just make sure you research it thoroughly before starting. one 1/8 yard panel is enough for tons of bags, so you can get that if you want. You can use other fabric as well, but I think using facile for the first was good because it got me used to the fabric right away.
That Bag Making Tutorial has some decent pages on it to check out.
