Fairy/Shut Crossbody Rake
Post by brinard »
TOE > SAME OUT [DEX] >> [XBD] RAKE [BOD] > SAME TOE [DEL]
okay, first i wanna know how many adds? second, i wanna know is there a way i can make this trick smoother... ive hit it about 1 out of 75 tries... iknow, practice, but i wanna get form down and not leave it to luck.
dazza
Post by dazza »
If the xbd rake is solid, this moves would be 4 adds, one for the set and
3 for the rake .
EASYKINKI
Chim-Chim
Post by Chim-Chim »
do you rake with the setting foot? either way.. keep the bag in your sight until your foot is about to rake it up.
Jake Raye
Post by brinard »
i set with my right foot
so right toe set> same out dex> op toe xbd rake.
thanks guys
Once you can do your fairy set straight up to your rib cage every time, do this, then turn your back to it slightly. That will help you position yourself correctly for a nice, straight rake. Try to keep the bag close-ish to your body for better control.
And try to keep your head right over the bag
