is a Sole Del. > Butterfly a 4 Add?
UNUSUAL SURFACE [uns]
You get this Add when you use any surface of the body besides the toes, insteps, outsteps and knees.
so does that mean that a sole del. is an add in itself? (and does my hand holding my foot negate that?) If so, it makes for quite an easy 4 add
- Iron Clad Ben
- Superior Precision Bionics
Kyle Hewitt
- something more funny
- james_dean
- space cowboy
soul > butterfly is a 4 add but you dont get any adds for the soul
Shreddaily wrote:
Started with sparse low lines, built intensity with rythmic variety, went to 16th note lines in high register, than went to octives, than block chords for my last chorus... If you understood that last sentance than you should be playing music and not checking the internet.
- max
- Australofrenchbrityorkus
I've meaning to ask a sole related question this for a while, and it's not completly off topic here so here goes:
When you do a sole delay it's usually "behind your back", so depending on which butterfly you do I'd venture to say that it couldbe a 4 add.
Let's say you do a sole delay with your right foot. The bag is usually behind you to your right. If you set and do a butterfly on your right (delaying with left foot clipper stall) then it's just a butterfly.
But if you set and the bg travels behind your back to your left and you then do the butterfly on your left (delaying with right foot clipper) I'd venture to say that that *COULD* be a gyro butterfly... (4 adds)
I'm thinking this is easy to "the" by setting the bag in a xbd sole position.
Maxime Boucoiran
French ConneXion
BFC
French ConneXion
BFC
That is an interesting point max
I wonder if anyone has tried spinning out of flapper before? If you could set stright from it then for sure it could be possible and ofcourse, would get a [BOD] add for the spin.
But soledelay > far butterfly and soledelay > near butterfly are both 2>3 combos, provided the bag passes in front of you and not behind.
There is no such thing as symp butterfly, but I believe (others don't) that there is such a thing as symp reverse whirl. If you do the oposite dex to whirl, the dex is full so it can be symp, butterfly dex is far from a full dex though.
