Do you think streching is important? I heard some people dont stretch at all
Flexebility
Flexebility
I believe it is important in footbag to increase it you have to stretch.I spend some time everyday stretching all kinds of muscles,specially my ankle's.
- Iron Clad Ben
- Superior Precision Bionics
I believe stretching helps to a certain extent. With more mobility in a joint, comes more instability. Meaning, if you're already flexible or hyperflexible, stretching isn't necessary as it is for people who are tight and lack normal flexibility. It's hard to differentiate what normal flexibility is if you don't have that knowledge handy, but if you do, going past that will leave certain joints instable and waiting for some sort of injury. So I preach stretching, just not overdoing it !
More C4 please <3
- full nelson
- 8-Bit Ninja
John's right. For example, a post you made a couple of threads down about walking on your outsides; that is not good. The more you stretch out the ligaments in your ankle, the more instable it is and more likely to sprain. Ligaments aren't very elastic. Once they're stretched, they're stretched for good. And since ligaments hold your bones together, they're pretty important.
But yeah stretching is important too, just do it within its limits.
Edit; I guess he hit that topic already too, haha.
Brad
You should aim to stretch muscles and tendons, not the ligaments, or other structures of joints.
Stretching makes your muscles twitch faster, and stronger in some cases. This helps a lot in footbag. The other thing is that you're faster, because you don't have to fight with the resistance of your own body. I mean - The resistance of the "opposite" muscles to the ones you're using doing a move is smaller.
And about stretching before session. You CAN'T stretch when you have "cold" muscles. You should stretch only when you're warmed up. Stretching muscles when their temperature ist just normal temperature of your body can make things only worse. It could cause some microdamages of your muscles, and that can make you suffer from a serious injury later.
The other thing about stretching before is that stretching (especially isostatic stretching where you hold your muscles stretched for long period of time (20-30 sec.)) makes your coordination worse.
You better use the time for doing some good warm-up. It will adapt your body to the exertion better than stretching.
Pawel Ptaszynski
NAS
Be strong, LIVESTRONG
http://www.laf.org
http://www.wearyellow.com
NAS
http://www.laf.org
Yeah... Older books may not contain conclusions from newer researches. Normall thing.
Even some of the older sport trainers talk about training things that are outdated an actually not very good. And the worse thing is that they use training methods that are old and not always good. The the athlets suffer.
This is how it is with sport teachers in polish schools, unfortunately... I don't think that all of them do so, but most of them...
Pawel Ptaszynski
NAS
http://www.laf.org
NAS
http://www.laf.org
Double post... please delete this one...
Pawel Ptaszynski
NAS
http://www.laf.org
NAS
http://www.laf.org
hackeysnacker
stretching helps reduce muscle tension, improve blood circulation therefore more oxygen flow which then means a delay of lactic acid build up, improves mental alertness, and increases the range of movement of body parts.
The main and popular stretch used is the static stretch where u hold a stretching position for 15-30 seconds.
A PNF (proprio neuro facilitation) stretch is a static stretch while the muscle being stretch is being contracted. This is the most effective stretch out of all 4 types of stretches.
So give this a go next time you warm up and cool down after sessions.
Jason Po
