Fairy/Shut Ripstein (Frankenstein)
Lee
Post by Lee »
TOE > SAME OUT [DEX] >> OP BACK SWIRL [DEX] > SAME BACK SWIRL [DEX] > SAME CLIP [XBD][DEL]
I've been getting really close to fairy ripstein.
I get all the dexes, but when I go to catch the clipper, I seem to hit the floor with my foot just as the bag does.
Any tips?
Uranos
Post by Uranos »
This really shud b in the tricktips section but..
I hit fairy ripstein recently, and the thing that helped me most was practicing downtime swirls (symple swirls might help a bit).
I think once you have the phasing set which should be a bit above knee high, the key to the second dex is to start it as fast as possible. I know symple swirls and the second swirl for this move are both different moves, but i found it helped alot.
Also school ripsteins :D
ANKLE DEX :!:
Alex Urano
Lee
Post by Lee »
Thanks, I'll work on it.
janis
Post by janis »
The thing that really helped me to hit this trick was to practice symple swirls heaps and phasing same clipper kick. I think of it as a fairy symple ripstein, with a quick fairy set and small dexes, I don't let the swirl leg drop much after the second dex. That said I'm not very good at this trick, so go with what feels right for you.
