Sides of Facile
Sides of Facile
How can you tell which side is better? i just got some swatches and cant tell!
Chris Patterson
here... i used the search option for you.... http://www.modified.in/footbag/viewtopi ... ultrasuede
DiceLiving...Let The Dice Decide
okay,
there are 2 sides to facile, and only 1 is good to use on the outside (ofcourse)
there is one side that is shiny, and will rough up noticibly when you rub your finger across the surface... like suede... this is the outside.
the other is duller, and will have little hairs, but will not rough up...
an easy way for me to tell is to tilt the panel towards an open window, and you can easily tell the textures/shinyness(cause the light). the good side looks ruffled, and will shine. that will be the outside.(i have a hard time telling darks sides.)
