Blurry Eggbeater (Bedwetter)
CLIP > OP IN [DEX] > OP OUT [PDX] [DEX] > OP OUT [DEX] > SAME TOE [DEL]
http://www.hackrifice.com/moves/5blurryeggbeat.wmv
I've hit this move on both sides, but I want some tips to see if I can revise it better. Any help?
Post by Senor Grommet »
I find that a really high stepping set can hurt my ability to hit this move b/c it then requires an even higher eggbeater, which is hard to do. I like to keep the set about belly-button high or a bit higher. Basically, you've gotta get your stepping foot back down to the ground as fast as possible so that you can push off very early and start the eggbeater dexes. It helps a lot to have really tight egg dexes, and you def. need to have a downtime eggbeater.
To increase your speed, you might with to practice some toe set eggbeaters but wait a bit to start the dexes after you set the bag. This will force you to per4form the dexes much faster if you are to hit the move. This will increase your egg dexing speed and make bedwetter easier.
Post by Muffinman »
Also practice pdx eggbeaters.
If you have a decent pdx eggbeater and a decent stepping then you should have a decent bedwetter. I had a really weak flip pdx eggbeater and that made flip bedwetter REALLY tough.
Uranos
Post by Uranos »
The faster you start the second dex of thismove, the easier :wink: but make sure you dont slurr the stepping set.
Alex Urano
smokefree
Post by smokefree »
damn dude.... if you can hit that you're a savage.
Anthony
MONKEY CLAW!
the Executioner
Post by the Executioner »
as inventor of this move :wink: i like to think of it as like a blizzard with an extra dex at the end. it also helps to skool pdx eggbeaters alot, as Erik pointed out.
Peter Irish
