TOE>same out [DEX]> opp. TOE[DEL]
TOE>same in [DEX]> opp. TOE[DEL]
any differnce?
how are theses different?
you are circling your leg around the bag in two different directions. In the first, you set the bag then dex from out-in(circling your teg towards your balls), while in the 2nd you are setting then dexing from in-out(circling your leg away from your balls).
Every trick is like this. Once you learn atw-in and atw-out you can easily notice the difference b/w in-out and out-in. Depending on what trick you are doing, you are either dexing the bag from in-out or out-in. So tricks like atw-out, fairy,legover, and illusion are out-in dexes, while tricks like atw-in, pixie, mirage, and pickup are in out dexes.
- Iron Clad Ben
- Superior Precision Bionics
- slapdash21
- Futureless
