Well, I only plan to get this footblog going until the end of summer. My summer started a little less than a month ago - and just today I found one of my footbags. I'm transitioning from middleschool to highschool (Yes, 8th to 9th) and I haven't contacted my friends or shredded with them at all so far this summer. The last thing I want is them to get ahead of me and it'd be nice if I could get some impressive stuff down before I enter high school.
My Current Status :
- Rod Lavers (8 Months Old)
- One New(ish) Mr Sandbag, and a bunch of old Mr Sandbags and
Sandmasters.
- 30 Bucks.
- Tricks : Around the World, Clipper (Consecutive Record is 21) , Reverse Clipper, Sole Stall, Leg Over (Half Assed, Can't Put it in A String), Pendulum.
Checklist of Goals :
[ ]- Two More 2 Add Tricks
[ ]- Four 3 Add Tricks
[ ]- One 4 Add Trick
[ ]- Great Quality 32 Panel Footbag
What I need right now is a bunch of suggestions. What tricks should I learn? What footbag should I get?
The challenge is to accomplish these (possibly more) before the end of summer.
I'm going to sleep, wake up tomorrow, see if I can still do the moves I've posted, and keep you updated.
Bringin Footbag Back Into Tad's Summer
Hey
I would advice to get your toe>op toe back in shape.Then master legover on both legs and mirages on both legs.
If you keep up good you'll be doin some nice strings.
Also try buttefly i think with your clipers it wont be that hard.
And use your imagination try and pull of a pendulous sole stall>cliper>cliper>flaper.
Good luck
Good luck
