Whirling swirl
Whirling swirl
SET>OP IN [DEX]>OP BACK (SWIRL)[DEX]>SAME CLIP[XBD][DEL]
I have solid whirls. I can do some swirls.
I searched for this topic. didnt find it.
Tips on whirling swirl
Attack the whirl so it is completed midtime. Use the explosive power of the whirl and focus that into the flowing swirl which should be natural and not forced. The swirling leg should be in motion just as the whirling dex is traveling in a downward motion. Thats how I do it at least.
Jon's FootBlog
MSN: [email protected]
- beenjammin
Youve probable noticed that with diving clippers you have to start the "dex" while the bag is rising. Whirling is the same way, you should have the dexing leg directly over the bag at its peak. Try to focus on starting the swirl as soon as possible. Youre the man Henry!
"Every cereal is my favorite cereal"
Ben Rinowski
Ben Rinowski
- Zac Miley
Whirling Swirl
Not really for tips, but I'd take some since I suck at this trick.
I'm mostly curious why Whirling Swirl doesn't get x dex?
[merged with whirling swirl thread - Frank_]
- Sporatical_Distractions
- registered sacks offender
Tips
The way I learned this is to do a quick whirl, but halfway through it do a symple swirl. So start the second dex before the first one ends.
- Zac Miley
Oh, my bad Ken. I checked the master list. Guess I should have used the search function.
Also, I always thought swirl was a full dex for some reason.
Thanks!
Thanks!
Be QUICK.
Set and then IMMEDIATELY plant your clipper foot, the IMMEDIATELY start your symple swirl. Your whirl will just have to fit itself in there somewhere. In approaching this trick in this "explosive" way, you might run across the problem of lossing control of your dexes and having you feet flail wildly, so as a side not make sure they are as tight and as controlled as possible.
Of course I don't need to tell you that your whirls and symple swirls should be solid.
Practice practice practice.
