I'm looking for a video of Little Apple. Anybody have it or can describe it better than this: Little Apple (ADD 4)
Spyro Symposium Mirage
Clip >> (back) Spin (BOD) >> (no plant while) Same In (DEX)(BOD) > Op Toe (DEL)
Thanks.
Little Apple Request (No Video)
- zeroman13
I might be able to describe it better.
• Spyro
Planted Gyro - Used with symposium tricks
Clip > (back) Spin [bod] > (same side)
So start the move like a normal gyro mirage but after the spin plant the leg that you set the bag with (if you were doing just a gyro mirage this foot would not be planted but instead would remain off the ground), raise the other foot off the ground, perform a symposium dex with the foot that was planted (in - out) and catch the bag with the foot that was in the air.
Hope that helps.
• Spyro
Hope that helps.
Jon's FootBlog
MSN: [email protected]
