Good stuff! when you do the sidewalk/stepping strings, switch it over to the other side, it makes you seem one sided when you show those off just with your right leg, but it's obvious you could tear it up stepping from your left legged clipper as well. double spinning clipper= sick!
DanJohnHarris wrote:Good stuff! when you do the sidewalk/stepping strings, switch it over to the other side, it makes you seem one sided when you show those off just with your right leg, but it's obvious you could tear it up stepping from your left legged clipper as well. double spinning clipper= sick!
His flip clipper used to be unusable, and he just now is figuring out how to use it.
But yes - try and flip it to the other side and then do something easy out of it! (I'm such a hypocrite)
your runs are very long, but sometimes i find them boring. you can hit more hard tricks in your run - that's my small advice. i loved remix of the song from the prison break.
