Vortex (gyro drifter)
CLIP>BACKSPIN[BOD]>>SAME IN [DEX]>OP CLIP [XBD][DEL]
Ugh, schooled this for a while and came up with some great tries and footed it a few times, but I need a little more consistant approach.
So far I've been doing the set, pivot, turn head thing, then spot the bag, then go for it. But it never comes out that smoothly, and many times I'm not able to pivot far enough to make a good attempt at the drifter. Thanks.
Gyro Drifter (Vortex)
- shredzilla
Ugh I suck at this trick but...
set it close to your body and make the spin smooth and dont even focus on the dex it should just happen
Jon's FootBlog
MSN: [email protected]
- King Monkey
Set it low and at a slight angle kinda towards and behind yourself if that makes sense. Its only slight, you dont want to much angle or you will kinda be slurring the move a bit perhaps. Snap your head around quickly to get the turn happening, and try to have a fairly tight drifter dex.
Practice doing just gyro mirages where you get everything done with alot of time to do the catch. This might help you get in the right motion to just turn it into a drifter, not a mirage.
This move is very fun and easy when you get used to it.
practice by doing a bunch of pdx drifters first to get your leg ready for that part. then practice by doing a bunch of gyro clippers where you turn before the bag peaks and spot it when it does. then practice by doing muted spinning clippers. then practice by doing vortex
as matt says, gyro mirage will help a lot too.
Good point.
I may have a decent vortex because I have a good gyro DLO.
Can you spin really well? Hmm. Maybe try consecutive "gyro" clippers, but with barely any plant -- this might help. The trickiness is in the plantlessness of gyro.
Setting low is also key for me. I've had to think a bit about how to vortex recently, since the drifter hurts my injured hip if I do it wong. I never really have a computer and a shred session at the same time, though, so it sucks that I can't give better advice by just trying the trick...
It's definately about a stop in momentum like a gyro clipper and then a drifter (though the drifter feels a bit different from regular drifter, of course...) Sorry, I feel like I didn't help much.
Get good at gyro...and get good at drifter >_____<Try> gyro clipper [repeat twice] > drifter > spinning clipper [REPEAT WHOLE THING]
If your style hasn't changed much since your last video, then I suggest working on just your clipper technique. Gyro and drifter are both heavily sensitive to what kind of clipper you're trying to use. You will achieve vortex sooner if you clean up your clippers, rather than trying to practice vortex with an unsteady clipper, no offense.
Like Jorden has said a few times, experiment with clipper more. Try turning and bending your torso, limbs, joints, head in different directions and angles so you don't get stuck practicing and strengthening the only clipper you know. That way you will gradually build a better sense of how clipper really works and guide your form in that direction, instead of learning to make do with what you have now.
If clippers get boring, work on other tricks that depend heavily on a good clipper, like swirls, spinning clippers, plain drifters etc.
CL: openFrameworks
CL: openFrameworks
- shredzilla
Eh, it's probably just a case of me jumping the gun on a move or concept. I just started schooling gyros for a while, and hit started getting decent at some of the moves, and even hit mobius at one point. Vortex was a big move that I wanted to hit, so I went for it. And I kept getting really close, or footing it.
I've kinda shelved this one for a while, and I'm sure when I come back to it it will be easier because my overall skill will have improved. Anyway, thanks for the tips, if anything it's good to have a thread for this move.
