setting consistency
Disturbedboy365
setting consistency
Post by Disturbedboy365 »
i'm having troubles setting from clipper, it always seems to hit my leg when i try to set it, are there any drills to help me set it straight up?
Austin French
It Is Decidedly So
Kljopa
Post by Kljopa »
ss cliperx10 :)
Post by C-Fan »
Also be aware that the type of bag you use can affect how it sets. Sandbags tend to stall more easily, but they are less round, and therefore don't set as "true." A rounder bag will leave your foot more consistently, but it is also harder to catch.
Disturbedboy365
currently i'm using a Travis Iden bag... it sets really nice its just that my motion is kinda screwy.
Austin French
It Is Decidedly So
MatS21
Post by MatS21 »
When you can hit ss clipper * 10, try to do them 3 different height sets.
start out first clipper set knee height, like for pick-up
second one waist high for dlo
third one neck high like for ducking
rpt
jay7
Post by jay7 »
There are, 2 big things in setting a clipper I do believe.
The clipper leg, which you use your knee and a bit of ankle to set.
The support leg, which you use to give a little more "pop" to it.
I assume since you are hitting your leg with it, that you are not setting enough with the support leg, thus your clipper leg's knee motion just throws it inwards.
I'd try out 100% support leg sets, [they wont go high at all] and then try a few with 50% support leg and then 50% clipper leg sets...
Oh, and practise pratise practise :wink:
Jay Boychuk
Baller Buddy
Post by Baller Buddy »
Definitely try and set the bag using your support leg and clipper leg. If you can time both of these perfectly with each other, it should be no problem setting it high enough for even a ducking trick. Hope this helps.
Matt E
A friend, A baller, A shredder
