Mr. sandbag to 32
flockpocken
Mr. sandbag to 32
Post by flockpocken »
When should i move up from a Mr sandbag to a 32 panel? and whats the best 32 to get?
sen
Post by sen »
You shouldn't switch, in my opinion, until you are doing alot of uptime moves. 32's make setting much easier. You should also make sure you can stall that mr in your sleep as a 32 is more difficult to stall.
As for which one you should get . . . that's pretty much up to you. I got a footfighter as my first 32 and was really happy with it. It was soft and broken in from the get go and I believe that makes a great starting bag.
flockpocken
ya.. i was thinkin about a footfighter... i still need to master my clipper stalls with my mr sandbag.
jay7
Post by jay7 »
I'd definetly say a footfighter is a good first 32. First off, it is big, second it is basically broken in when you get it, third, if you are buying from Kool Kolo, well, he rocks.
My first facile 32 was a big surprise, basically unplayable, because I wasn't properly stalling and the like, so take that into consideration as well.
Jay Boychuk
flockpocken
so should i get the mini or regular? cause i find myself tipping the bag when i dex with my upper leg.
Post by HG »
i dont know why people say mr sandbags are easier to learn with. I cant play with a mr sandbag to save my life, 32's are so much easier to stall than a sandbag. Maybe its just me, but switch to a 32 (a quality one, make sure) as fast as you want, because they are infinitely better.
flockpocken
so what quality bag do you suggest?
i got 2 saying to get a footfighter
Guest_1
Post by Guest_1 »
You should get a regular sized 32 from someone like Josh Raye or Holly
Post by brinard »
my bags are alittle small, so i wouldnt reccommend them.
i would however, recommend in this order for larger bags (larger being slightly larger than a golfball.
holly
aiden
hermey
ff
