Math Open-Ended Question
xpawel18x
Post by xpawel18x »
Guys, I need some help here with this open-ended question from my Algebra 2+Trig class. If anyone wants to go at it, I'd greately appreciate it.
Rectangles A and B are similar. The area of Rectangle A is 30.195 cm squared. The length of Rectangle B is 6.1 cm. Each dimension of Rectangle B is 2/3 of the corresponding dimension of Rectangle A. What is the perimeter of Rectangle B. Explain your answer and show all the work.
Nitrox
Post by Nitrox »
Ok...
So for rect A you have x * y = 30.195
And B you have l = 6.1
And you know the sides of B are 2/3 that of A, therefore you know x (or length of A) is 9.15
And you know x * y = 30.195, and now you know x, so you know y must me 3.3
Then, using the whole 2/3 thing from before, you know w of B is 2/3 of y, or 2/3 of 3.3, or 2.2
So now you know both of the sides of rect B, 6.1cm and 2.2cm
Just add 'em up times 2 and you get the perimeter :)
16.6cm
I hope I did an ok job explaining it instead of just giving you the answer
If you're confused about any part of it just go ahead and ask!
--Josh Ohana--
My Blog
Challenge Me
xpawel18x
Post by xpawel18x »
That was quick! I understand it, Thank You Nitrox. :D
Nitrox
Post by Nitrox »
hehe, no problem...I like math :P
It's oddly fun helping like that so feel free to ask all the questions you want! Just specify what kind of answers you want (explantion, answer, both?)
--Josh Ohana--
My Blog
Challenge Me
