Sets list 2004
- Chris Holden
- Dolla Llama
Sets list 2004
As some of you know, I've been keep up to date with this list for several years, replies should be limited to questions concerning sets or posting of new set concepts to be added to the list.
Sets : Uptime moves
Toe
Pixie: TOE > SAME IN [DEX] > (op/same side)
Fairy: TOE > SAME OUT [DEX] > (op/same side)
Atomic (reverse miraging): TOE > OP OUT [DEX] > (op side)
Tapping (Atomic same side): TOE > OP OUT [DEX] > (same side)
Quantum (miraging): TOE > OP IN [DEX] > (op side)
Slapping (Quantum same side): TOE > OP IN [DEX] > (same side)
Terraging (Double Pixie): TOE > SAME IN [DEX] > SAME IN [DEX] >
Sailing (Pixie Atomic): TOE > SAME IN [DEX] > OP OUT [DEX] >
Frantic (Pixie Quantum): TOE > SAME IN [DEX] > OP IN [DEX] >
Fusing(Fairy Atomic): TOE > SAME OUT [DEX] > OP OUT [DEX] >
?? (Double Fairy): TOE > SAME OUT [DEX] > SAME OUT [DEX] >
Delusional (Double Illusion): TOE > OP OUT [DEX] > OP OUT [DEX] >
Wonton (Symposium Quantum): SET > (no plant while) OP IN [BOD][DEX] >
Flailing (Symposium Atomic): SET > (no plant while) OP OUT [BOD][DEX] >
Wontomic (toe shooting, symp quantum atomic): TOE > (no plant while) OP IN [DEX] > OP OUT [DEX][XDEX] >
Phasing (fairy swirling): TOE > SAME OUT [DEX] > OP BACK SWIRL [DEX] >
Surfing (Symposium Phasing) TOE > SAME OUT [DEX] > (no plant while) OP BACK SWIRL [DEX][BOD] >
?? Gnome (atomic/tapping swirling): TOE > OP OUT [dex] > OP SWIRL [dex] >
Warped (symp atomic atomic, symp eggbeating): TOE > (no plant while) OP OUT [DEX][BOD] > OP OUT [DEX][XDEX] >
Clip
Stepping (clip set miraging): CLIP > OP IN [DEX] > (same side component)
Blurry (Stepping Paradox): CLIP > OP IN [DEX] > (op side paradox component/op side dexterity does not have have to be paradox, though all blurry named moves are paradox)
Pogo (Symposium Stepping): CLIP > (no plant while) OP IN [DEX] > (not full dex, does not recieve symposium add)
Bubba (clip set illusion): CLIP > OP OUT [DEX] >
Nuclear (clip set atomic): CLIP > SAME OUT [PDX] [DEX] >
Quasi (Paradox Miraging): CLIP > SAME IN [PDX] [DEX] >
High Stepping (Barraging): CLIP > OP IN [DEX] > SAME IN [DEX] > (same side component)
Furious (Barraging Paradox): CLIP > OP IN [DEX] > SAME IN [DEX] > (op side paradox component)
Shooting (Stepping Paradox Illusion): CLIP > (no plant while) OP IN [DEX] > OP OUT [PDX][DEX] >
Rifling (Stepping Double Switch Over): CLIP > (no plant while) OP IN [DEX] > OP OUT [DEX] > SAME OUT [DEX] >
Sliding (Stepping Paradox Mirage): CLIP > (no plant while) OP IN [DEX] > OP IN [PDX][DEX] >
Spinning
Pyro(Pixie Gyro): TOE > SAME IN [DEX] > (BACK) SPIN [BOD] >
Fyro(Fairy Gyro): TOE > SAME OUT [DEX] > (BACK) SPIN [BOD] >
Sonic (gyro spinning): CLIP > (BACK) SPIN [BOD] > (BACK) SPIN [BOD] >
Peeking (double gyro): SET > (BACK) SPIN [BOD] > (BACK) SPIN [BOD] >
(peeking is set, spot the bag [like osis], then spot the other way, thus peeking over your shoulder at the bag twice)
Leaning (stepping inspinning): CLIP > OP IN [DEX] > (front) SPIN [BOD] >
Go-go/Cubic (stepping backspinning): CLIP > OP IN [DEX] > (back) SPIN [BOD] >
Lateral (atomic backspinning): TOE > OP OUT > (back)SPIN [BOD] >
Surging (gyro miraging): CLIP > (BACK/FRONT) SPIN [BOD] > OP IN [DEX] >
Gyro Shooting (Surging Atomic): CLIP > (BACK/FRONT) SPIN [BOD] > OP IN [DEX] > OP OUT [DEX] [PDX]
Twinspinning (nuclear inspinning): CLIP > SAME OUT [DEX] > (FRONT) SPIN [BOD] >
(Tapping spin): TOE > OP OUT [DEX] > (FRONT) SPIN [BOD] >
??Neutron (Atomic spin): TOE > OP OUT [DEX] > (BACK) SPIN [BOD] > (op side component)
Whirl/swirl
Swirling/Burly: CLIP > SAME BACK/FRONT SWIRL [DEX] >
Smiling (swirling stepping): CLIP > SAME (FRONT/BACK) SWIRL [DEX] > OP IN [DEX]
Whirling: CLIP > OP IN [DEX] > (same side component)
Blazing: CLIP > OP IN [DEX] > (op side component)
Scattered (Reverse Whirling): CLIP > OP OUT [DEX] > (same side component)
Shattered (Reverse Whirling): CLIP > OP OUT [DEX] > (op side component)
Blistering (Whirling Gyro): CLIP > OP IN [DEX] > (BACK) SPIN [BOD] > (gyro component)
??(clipper reverse whirl spinning): CLIP > OP OUT [DEX] > (BACK) SPIN [BOD] >
UNS set:
Snapping (Dragon set Swirling): DRAGON > SAME FRONT SWIRL [DEX] >
Twisted (Dragon set Swirling Paradox): DRAGON > SAME FRONT SWIRL [DEX] > SAME IN/OUT [PDX][DEX] >
Frozen (frigidosis Atomic) FRIGIDOSIS > OP OUT [DEX] >
Arctic (frigidosis Pixie): FRIGIDOSIS > SAME IN [DEX] >
Antisymposium:
Rooting/Rooted (antisymposium): plant the setting foot (op leg does not plant), jump with the setting foot, setting the bag in the air.
Zoid: rooted crossbody toe set
Hyper (rooted pixie): [root] toe > same in [dex]
?? (Rooted Fairy): [root] toe > same out [dex]
Similar components, not neccessarily sets:
Ducking: SET > DUCK [BOD] > (op side)
Diving: SET > DIVE [BOD] > (same side)
Weaving (ducking same side): SET > DUCK [BOD] > (same side)
Zulu (diving op side): SET > DIVE [BOD] > (op side)
Spinning: SET > (BACK) SPIN [BOD] >
Inspinning: SET > (FRONT) SPIN [BOD][BOD]>
Gyro: CLIP > (BACK) SPIN [BOD] > (same dex component, setting foot does not plant on gyro except for symposium moves)
gimpy (stepping op knee bump): clip>op in>op knee bump
pimpy (pixie same knee bump): toe>same in>same knee bump
Finchy (Pinching Fairy set): PINCH > SAME OUT >
Pixie Pinching: PINCH > SAME IN >
Pinch sets are not full dexs, thus do not recieve the dexterity add fairy/pixie only indicate the direction the bag is set.
Sets : Uptime moves
Toe
Clip
Spinning
Whirl/swirl
UNS set:
Antisymposium:
- wolfpac444
- Your Friendly Admin
Swixie: Crossbody Pixie / Anticlipper Swirling
XBT Toe > Same Back Swirl (DEX) >
Edit: Thanks dil!
Edit: Thanks dil!
Michał Biarda (Me-how Be-r-da)
It would just be silly to list every existing set from a different position.
Example: Neo (which is a fairy set from an inside delay).
this is the 44 Wand, the most powerful Handwand in the world, so did i fire 5 or 6 fireballs? now you got to ask yourself one question pal, do i feel lucky? well do ya punk.
Yves Krail hit Pixie - Fairy several months ago
Toe > Same In [DEX] > Same Out [DEX] >>
Pawel Ptaszynski
NAS
Be strong, LIVESTRONG
http://www.laf.org
http://www.wearyellow.com
NAS
http://www.laf.org
hacksterbator
- Washed-Up Child Star
- Chris Holden
- Dolla Llama
Thanks guys! I knew most of these, this list is rather old, so I just posted it quick without my updates (in a seperate file).
What I may do for slight variations, such as Neo set, is list it under fairy. This way, we won't have to list things multiple times, but get all of the proper titles across. Similar with symposium variants. Some sets performed symp are literally the same as their non-symp components, like symp frantic vs. frantic, completely performed the same way, minus a plant. They are SO close to the same thing, if you can hit one, you can hit the other.
j/k, lets call outside set pixie Deez set, liek Deez Nuts, cause Daryl always uses this set.
- ShredPirate
- Punkass
i originally called it symp omelette set in my first post, but i also said it's like a symp eggbeater set within that same post. eveyone started calling it symp eggbeating from then on. and i just went with it. so yes, it is technically symp omelette set because legover cannoy be involved in a set, AND because after the set, you assume the next component will be op side.
Chris Pinkus
- bigdirtyfoot
- Sloppy
ShredPirate wrote:
Big dirty foot wrote:AND because after the set, you assume the next component will be op side.
Ok so wait, are you saying that for a set to be a set, then next component must be op side? absolutely not!!! Pixie ss mirage. Pixie set. Parkwalk, Pixie set ss butterfly, Furious George, barraging set ss double over down...Wait wait wait. Just help me out because all of a sudden I feel like newbie again. Is this true with ALL sets? I was wondering this over the past week. This would help me out tons.
Chris May
- Chris Holden
- Dolla Llama
bigdirtyfoot: it's 'important' that some sets have an op/same side name variation because the performance of these moves is slightly differnt when performed on different sides. I believe Atomic set is the a good example, because of how the bag goes from one side of the body to the other (thus xdex), where as tapping (same side atomic) is performed just a bit different.
I've recently experienced this with Nuclear, Matador vs. Barfry. I actually perform the Nuclear dex differently.
Again, this doesn't work with all sets, but when you're performing the moves, you can feel a difference.
comastalker
does a rooted set get a an extra add because of its symp character ?
hit rooted zulu symp mirage today and thought about how many adds it would get. Without the rooted add it would make a 4-add. It's far too easy for being my first 5-adder
-Richard Vock-
"And today the great Yertle, The Marvelous he,
Is King of the Mud. That is all he can see.
And the turtles, of course...all turtles are free
As turtles and, maybe, all creatures should be."
- Dr. Seuss
- Dr. Seuss
