X-dex
X-dex
I don´t realise x-dex so well. Could someone explain it. I know that if trick has two full dexes in it, it get´s x-dex. Like Atom Smasher. But if trick has three full dexes in it, does it get two x-dexes? Like Warp. And what are full dexes? I know that Mirage and Illusion are. But is Pixie? For example does Smear get x-dex? Help me out.
- max
- Australofrenchbrityorkus
this is how I understand it:
2 full dexes gets you and extra add: the X-DEX
Every additional full dex after that gets an extra X-DEX also.
A full dex is a mirage or an illusion.
Exceptions: a mirage set from clipper (clip > op in) does net get an x-dex.
pixies, fairies, pickups, legovers, steps and butterflies are considered NOT full dexes.
You can apply symposium to everything stated above, it still holds.
example:
atomsmasher: toe > op out > op in > op toe has 2 full dexes (a toe set mirage and an illusion). So it gets an X-DEX.
blur: clip > op in > op in > op toe has 1 full dex as the first dex (the step) is not considered full.
warp: toe > (no plant while) op out > op out > op in > op toe has 3 full dexes and gets 2 X-DEX adds.
genesis: clip > op in > same in > op in > op clip has 2 full dexes (the second and third, the first is not considered full) andgets one X-EDX add
as for X-SPIN, I'm not quite sure what it is. I think it's an extra add rewarded for inspinning. Anyone know?
example:
Maxime Boucoiran
French ConneXion
BFC
French ConneXion
BFC
StickyRicky
- Shredalicious
Max: I think that Fairy > Op Side Component is a full dex.
Inspinning Osis have x-spin because there are two full spins.
Double Spinning Clipper have X-Spin because there are 2 full spins.
Spinning Osis don't have X-Spin because there is 1,5 full spin.
Pawel Ptaszynski
NAS
Be strong, LIVESTRONG
http://www.laf.org
http://www.wearyellow.com
NAS
http://www.laf.org
Personally I think the only moves that should get an x dex are moves that have a full dex up time and a full dex downtime. I also don't think that you should be able to mix and match the fullness of dexes to get the most adds. Ie barraging set is not a half dex followed by a full dex - it's 2 unfull dexes. A double bubba set would be two full dexes.
So Nemesis doesn´t get x-dex?Jeremy wrote:Personally I think the only moves that should get an x dex are moves that have a full dex up time and a full dex downtime. I also don't think that you should be able to mix and match the fullness of dexes to get the most adds. Ie barraging set is not a half dex followed by a full dex - it's 2 unfull dexes. A double bubba set would be two full dexes.
I think I disagree with this. I think it's a half dex (stepping) with the hippy part of your leg, and a full dex (quantum) with the leggy part of your leg. The lower part of your leg definitely does a full dex. Jani Walker wouldn't get x dex, because there's only 1 full dex, but Nemesis should. There's 2 full dexes in there, each leg does one.Jeremy wrote:Ie barraging set is not a half dex followed by a full dex - it's 2 unfull dexes.
- shreddaily
- Flower Child
This is only based on my expierince with spinning.
I think inspining should only get the extra add if you a dex in the opposite direction of the spin.
ie inspining pdx mirage- x-spin 5 add
inspining osis- no x spin 4 add , no change in momentum
inspining same SIDE butterfly(same side after the spin is complete, ie same foot catches bag)- x sipn 5 add
inspining butterfly- no x spin 4 add, no change in momentum
inspining ss mirage-(what peter Irish does alot) no x-spin 3 add, no change in momentum.
This is kind of like the swirl issue. Once you have inspining it isn't that bad. I think peter irish and allan hagget would agree with me that inspinging osis is NOT a 5 add move. However moves where you have to inspin, then stablize and/or plant, than do a move, deserve the x add
i Also think double spining doesn't deserve x spin two adds for two spins.
double inspining however, well ask Allan about that...
I wouldn't give it one. I'm not sure what the official verdict is.AA wrote: So Nemesis doesn´t get x-dex?
All the barraging sets I have seen have looked like one action to me, as does the barfly at the end. It's hard enough to be a 7 add, but the add system works on reasons - not on how hard it feels.
But with X-Spin we don't talk about change twist direction.
It's about second, third, fourth FULLL spinn... It's oficial in that way...
Pawel Ptaszynski
NAS
http://www.laf.org
NAS
http://www.laf.org
comastalker
Are spinning momentum changes given tribute anyway ?
I think that the different spinning directions in inpinning ss torque are so fucking hard I's give them two extra adds.
-Richard Vock-
"And today the great Yertle, The Marvelous he,
Is King of the Mud. That is all he can see.
And the turtles, of course...all turtles are free
As turtles and, maybe, all creatures should be."
- Dr. Seuss
- Dr. Seuss
To AA:
On footbag.org/forum is one sticky topic about X-DEX ... Check it out ;]
Pawel Ptaszynski
NAS
http://www.laf.org
NAS
http://www.laf.org
This is the link to the x-dex sticky on footbag.org
It includes Eric Wulff's original definition of x-dex.
http://www.footbag.org/forum/viewtopic.php?t=319
Old Skool
- krawallier
by definition nemesis gets an xdex, that is for sure - similar to plasma (or fusion
true, the barraging set ( or at last mine) is one motion, but that motion is totally similar to quantum - and quantum obviously qualifies for xdex...
barraging isn't similar to pixie and stepping sets, which are the in-out ones that don't qualify for xdex...
and IMO a bubba set qualfies for xdex already -e.g. a bubba mirage like a clip set atom smasher - is as xdexy (xsexy) as it gets.
and a double bubba set
max kerkhoff
fcfootstar
! 30TH ANNUAL IFPA WORLD FOOTBAG CHAMPIONSHIPS 2009 - BERLIN !
fcfootstar
Can't speak for Pete, but I don't agree with youshreddaily wrote: I think peter irish and allan hagget would agree with me that inspinging osis is NOT a 5 add move.
Spinning osis is a four add move.
"Gyro" clipper is a 3 add move because you get an add for the "spin" involved. The spin in this move is the same degree of difference between spinning osis and inspinning osis.
I consider Inspinning Osis a 5.
Would I be repeating myself unnecessarily if I mentioned again how little I care about adds? Call Inspinning Osis a 2 add move for all I care
- shreddaily
- Flower Child
Not as such.Shredster wrote:Bubba set would get xdex, wouldn't it?
Think...from right clipper, left leg under then over...xdex.
A set cannot get x-dex all on it's own. An X-dex is built from at least two dexes.
This bubba set move would get an x-dex
Clipper set Atom Smasher.
clip > op out > op in > op toe.
In adds it would be clip > op out [1] > op in [1] > op toe [1] > x-dex [1]
Note that the x-dex is completed after all the necessary requirements are fulfilled.
Old Skool
