David LE's footblog..
SmellMyFinger
Post by SmellMyFinger »
Hello, welcome to my footblog.. I'm 15 years old and I kicked it around for only about 2 weeks before discovering freestyle. I started freestyling in early May of 2004.so that's almost 2months since i started. The first trick I learned was a downtime pixie, then atw in the same session. Now, i can hit mirages, pixies (uptime), ATW, legovers(my flipsided legovers need some work), and clippers (my clippers are still weak)..
I've hit several butterflys, and some symp mirages.
Most of my sessions are spent schooling the 2 adds i have and stuff.
In today's session, i started to try illusions and i hit those several times. I also got really close to DLO's... i want to be able to hit those soon.
thanks for reading.
David Le
I play Russian Roulette everyday.. a man's sport... with a bullet called life.
Samurai
4square Warrior
Post by Samurai »
FIRST POST!!! :D
Shreddaily wrote:
Started with sparse low lines, built intensity with rythmic variety, went to 16th note lines in high register, than went to octives, than block chords for my last chorus... If you understood that last sentance than you should be playing music and not checking the internet.
