Stepping/Blurry
- Posi-Cole
Stepping/Blurry
I have a decent stepping set.... Nothing spectacular, but it's not that terrible either.
However, I find that 90 percent of the moves I hit out of stepping are always done out of a clipper. In fact, I have a bit of difficulty stepping when I do a butterfly, but can step relatively easily when it is just a clipper.
I'm just wondering why this is, as essentially they should be the same I would think. Should I simply school stepping from butterfly more? Or just learn better stepping general and then it will be easier from butterfly? Has anyone had this problem before?
Any help would be great.
[merged into stepping/blurry - Frank_]
Cole Hobson
- mosher
- brutal footbag cronie
I think the difficulty is derived from the fact that with a stepping set starting from a clipper you have the advantage of the momentum being in your favour. The balls path makes more of a smooth U shape than when coming in from the other side of the leg as in a butterfly.
It's all momentum, the big thing Ive been finding is really trying to be in surefooted control of the bag before launching the step.
brian relly
- fan-tas-tic
I tend to have the same problem, but I don't know why it is, either. I find that it usually only happens when I plan to hit a stepping move out of a butterfly, or when I really try to. If I've just pulled off a big move that I don't hit regularly, I just keep going without thinking about it too much. That's usually when I'll hit a butterfly to ripwalk, or schmoe, or something.
I tend to find that when I have trouble linking particular tricks, the problem is in the first move.
I would recommend drilling your butterflies and maybe holding the stall at the end (for a few seconds - only while practicing) - once your butterflies become more solid, you'll be able to do anything out of them.
I agree with Jeremy. To step out of a butterfly the same way you are able to step out of your clipper, you must remember to catch the butterfly the same way you catch your clipper. My guess is that you are holding the bag a lot less when you hit your butterfly, but that your clipper is really solid and you catch it a lot more without the dex. Just practice stepping out of butterflies, and focus on that small pause and dip right before the stepping set. Also try to hit as many butterflies in a row as you can while focusing on control.
Always Shreddin
James Erickson
James Erickson
Guest
hmmm... I'm just learning stepping sets right now and I find it much easier to do stepping sets out of butterflies... especially ss butterflies. When I try to do them just off of clippers it always gets stuck/hits the back of my knee. I think it's maybe because my clippers stick out too much.
Rory "Tophat" Dawson
I used to have this problem. I think this is usually because of the momentum of your dexing leg changing - ie going from a out dex to a short plant straight into an in dex. Best way to solve this is to change how your butterfly dex dexes. Instead of going around the bag, you shouldn't need to move it much, let the bag do most of the work - "fall" into the butterfly... I'm sure this tip would be better explained in some other butterfly thread. But anyway, that should make the momentum shift easier.
Other thing is where your clipper foot is in relation to your dexing leg before the step - the further away it is, the harder it is to step in time. This is obvious, but alot of the time a person's clipper foot will be further away from the support/dex leg in a butterfly than in a clipper, so watch how you're landing those buterflies.
Hope it helps.
Hope it helps.
Liam Johnston
Palmy rules still apply
I had the same problem and still do sometimes. But i did notice a slight improvement by after getting butterfly to stepping decently down that if you do larger tricks ending in butterfly it will also clean it up more and more. Like i had trouble with dimwalk>ripwalk and it was because i depended to much on momentum rather than leg speed on my dimwalk so i'd end up with my support leg bent the wrong way to step. So if you just do butterfly or anymoves you're having trouble getting into stepping and concentrate on using legspeed more than momentum it should help theoretically and it worked for me so i guess it might work.
Ricky Holton
Stepping/Blurry
Stepping/Blurry
CLIP > OP IN [DEX] >>
http://hood.012webpages.com/_videos/Stepping.wmv
if someone could give me a couple of tips on stepping that would be great, thanks.
tip 1: keep the clipper close to your support leg
tip 2: keep upper body slightly leaned over clipper for balance
tip 3: keep clipper ankle cranked
tip 4: jump HARD off of your planted leg, bringing your knee up and from in to out faster than the bag, the key being faster than the bag
tip 5: after your knee beats the bag up and out, bring that leg back down to the ground quickly
good luck
good luck
Hey kur7ler, this is the link that Kaos gave me a while back when I posted for help with stepping and atomic sets:
http://list.footbag.org/majordomo/lette ... ite.com%3E
I also want to say that if you lift your knees higher during the stepping set, everything becomes a lot easier, at least for me! Good luck!
Kaushik Amancherla
Be sure that the setting leg is the first leg to touch the ground. If you plant
both legs simultaneously you won't have as much height for you stepping leg and your landing will be harder. For the step, quickly bend your leg upwards and outwards on your hip.
edit: fixed typo.
edit: fixed typo.
bjoern
Munich Footbag
Munich Footbag
qlunch
PostPosted: Thu Mar 10, 2005 9:43 pm Post subject: Stepping Set Reply with quote Edit/Delete this post Delete this post View IP address of poster
I'm getting pixie set tricks down, and it seems that stepping set should be the next set to tackle, i realize its been touched on in other posts but if someone could just run me through what they think about while excecuting and the motions i'd appreciate it. I just have no idea how to approach it. Thanks!
ps @Matt Cross - i've been hitting legit datw's!
_________________
Sean Gibson
"Facts are stupid things" - Ronald Reagan
Back to top
View user's profile Send private message Send e-mail
NuR
PostPosted: Thu Mar 10, 2005 9:53 pm Post subject: Reply with quote Edit/Delete this post Delete this post View IP address of poster
there is a similar thread on the second page of "trick tips" called
"stepping sets" .
Krafty posted a very helpful link there, check it out Smile
And good luck with stepping practice !
shred on !
_________________
" von nix kommt nix "
- bavarian zen koan -
www.munich-footbag.de
Daryl Canady
Back to top
Uranos
PostPosted: Fri Mar 11, 2005 5:08 am Post subject: Reply with quote Edit/Delete this post Delete this post View IP address of poster
Tips for stepping:
Keep clipper foot close to ground
Dance around the bag (Ales told me this)
Keep body position balanced and upright.
Jump off support leg.
Good luck!
_________________
Alex Urano
Melbourne Footbag Club
Read my blog here:
http://www.modified.ca/footbag/viewtopic.php?t=11782
Back to top
View user's profile Send private message Send e-mail Visit poster's website MSN Messenger
qlunch
PostPosted: Fri Mar 11, 2005 10:31 am Post subject: Reply with quote Edit/Delete this post Delete this post View IP address of poster
Whoops, guess i didn't see that thread Embarassed I checked it out and all this stuff is great, thanks a lot. I'll be hitting ripwalks before you know it, at least thats the plan Wink
_________________
Sean Gibson
Back to top
HooD
HoodluM
PostPosted: Fri Mar 11, 2005 12:32 pm Post subject: Reply with quote Edit/Delete this post Delete this post View IP address of poster
Don't know if you've seen this before or not, but here it is. All the way at the bottom is stepping set tips, there is also a video of 3 different people doing stepping sets next to the tips, it includes slow-mo so you can study the movements. Hope this helps.
http://hood.012webpages.com/TV%20Room/sets.html
_________________
John MahooD
WV Crew Footblog
www.hoodshouse.com
Back to top
View user's profile Send private message Send e-mail Visit poster's website AIM Address MSN Messenger
qlunch
PostPosted: Sat Mar 12, 2005 2:09 pm Post subject: Reply with quote Edit/Delete this post Delete this post View IP address of poster
Thanks hood that was really helpful, there were sets on there ive never even heard of. Landed a zoid mirage.... and back to the stepping set, still working on that
_________________
Sean Gibson
_________________
Sean Gibson
Back to top
NuR
"stepping sets" .
shred on !
_________________
Daryl Canady
Back to top
Uranos
Tips for stepping:
Good luck!
_________________
Alex Urano
Read my blog here:
Back to top
qlunch
_________________
Sean Gibson
Back to top
HooD
HoodluM
_________________
John MahooD
WV Crew Footblog
www.hoodshouse.com
Back to top
qlunch
_________________
Sean Gibson
ted
PostPosted: Tue May 10, 2005 12:38 pm Post subject: Stepping sets Reply with quote Edit/Delete this post Delete this post View IP address of poster
Hey,
I want help with stepping sets. I have them well enough to hit most 5's and some 6's and sometimes alpine but I want clean, monster sets. Anyone with big, easy steps (Maraxus, Full Nelson, Hacksterbator, etc.; I am looking your way) have any tips?
_________________
Theodore Anderson
Property is Robbery
Back to top
FootbagGuru
PostPosted: Tue May 10, 2005 4:59 pm Post subject: Reply with quote Edit/Delete this post Delete this post View IP address of poster
for a good set, just get your leg over it as fast as you can, i've recently been doing some alpine stepping stuff, and i find that helps
_________________
~Gravity is a suggestion, not a law~
Back to top
View user's profile Send private message Send e-mail AIM Address MSN Messenger
Erik Chan
PostPosted: Tue May 10, 2005 5:52 pm Post subject: Reply with quote Edit/Delete this post Delete this post View IP address of poster
I think the key to clean stepping is to set the bag before thinking about the dex; this is what I do and I don't think I ever the stepping sets (except probably pogo). I've seen lots of the stepping ducking -- it's important to set the bag FIRST and then just dex ridiculously fast. Maybe think about setting the bag straight up, but at your side, and then once it's set, step into it, instead of thinking of setting the bag directly between your legs (more vulnerable to "pulling") -- does that make sense?
_________________
http://www.hackrifice.com
Back to top
View user's profile Send private message Send e-mail Visit poster's website AIM Address Yahoo Messenger MSN Messenger
ICQ Number
PostPosted: Sat May 14, 2005 10:23 pm Post subject: Reply with quote Edit/Delete this post Delete this post View IP address of poster
Im not amazing at them but here it goes:
things to keep in mind:
1) I believe the highest sets are generated by a clipper foot moving upwards with the greatest velocity, so . . . you need to practice the shear speed of your upward set.
2) To have the most control over your set, you need to achieve good enough ankle crank so that you are setting straight up rather than outwards in some direction or another. Attain as much crank as possible to isolate a straight set.
3) For high sets, clipper as close as you can to your support leg, rather than far away from it.
4) When you delay the bag, try to accentuate the 'stall' by going down with the bag before you go up with it. In other words, delay the bag on the way down more tha usual in order to maximize lift on the way up
5)Timing is key. I think that you can start the step to early or you lose height for the clipper set. Your step needs to occur after you start setting the bag, but of course not too late so that it hits your leg on the way up. Find the timing that works for you, but really work on clearing the bag with the crook of the knee.
6) Try these sets when you're fresh, not when you're tired.
Good luck!
_________________
From Shredder to Master Stitcher to Sensei, Senor Grommet does it all . . . while maintaining his super-sized ego. Many have asked Grommet, "How DO you do it?" Truthfully, I answer, "I don't know. I guess I'm just really talented."
Back to top
habitat
PostPosted: Wed May 18, 2005 2:00 pm Post subject: Reply with quote Edit/Delete this post Delete this post View IP address of poster
wow great tips mirk, they all make total sense. I need to keep mine close to my leg and body
_________________
James Randall
Hey,
_________________
Theodore Anderson
Property is Robbery
Back to top
FootbagGuru
_________________
Back to top
Erik Chan
_________________
Back to top
ICQ Number
Good luck!
_________________
Back to top
habitat
_________________
James Randall
