awww... abshire leakage?
skimhumboldt?
Post by skimhumboldt? »
has anybody had a abshire mini leak? i got one, ive had it for a week and kicked it around for no more than 2 hours, ive gently washed it about three times, and ive massaged it a bunch. each time i kick it it seems like it gets squishyer and squishyer. when i first got it it was packed with pellets, now when i pinch it down forcing all the pellets to the bottom, the bag only has 2/3s of filling. Is it leaking or is it breaking in increadibly fast?
Isaac Williams
PM me if you want to trade 32s
Post by HG »
its doing both.
there are "bleed" holes in between the small panels. So where a small panel meets another small panel, its not sewn. This makes for a small amount of leakage, which you will be able to put back in later when it is broken in.
Dont worry.
Guest
Post by Guest »
Hey!
unless you can see pellets leaking out of the bag, don't worry about it. It's most likely just breaking in, and when it breaks in, the bag gets larger, so it won't be as full.
